BJM Posted 26June, 2014 Report Share Posted 26June, 2014 I can look after it till you get back...... Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 26June, 2014 Report Share Posted 26June, 2014 In this case we don't need to replace the pistons and/or cylinders. If one was to do so you'd probably go JE and Mahle 3.8 respectively but they're ~$5k plus there is some additional machining required. Given the condition of the engine we can reuse the existing pistons and cylinders with new rings, springs & retainers, seals, gaskets, conrod bolts, head studs and bearings etc. Engine will also be blueprinted and balanced, receive new cams and the aforementioned rockers and oil pump. Can't recall what was said about line honing (assume it would be done) and boring and resurfacing the cylinders (don't think it's necessary unless fitting oversized pistons). Then there are all the ancillaries like dizzy caps, rotor buttons, leads etc etc. No doubt a heap of things I've missed there. Thanks for the detailed reply. Can i ask a ballpark for what it costs just in parts for the motor bits? Quote Link to comment Share on other sites More sharing options...
Uncle Posted 26June, 2014 Report Share Posted 26June, 2014 Why not go with ITB's if you're planning to run some higher duration cams etc? Quote Link to comment Share on other sites More sharing options...
JV911 Posted 26June, 2014 Author Report Share Posted 26June, 2014 Why not go with ITB's if you're planning to run some higher duration cams etc? Funny you mention that! Waiting on a price on GT3 plenum and ITBs like on Sydr's car but think I might be a bit exxy. Thanks for the detailed reply. Can i ask a ballpark for what it costs just in parts for the motor bits? I actually don't know the exact breakdown but a full rebuild typically runs to $23-25k depending on what can be reused and top end rebuilds approx $15k. It can vary greatly especially if you need big ticket items like pistons and cylinders ($5k) If I had to guess, labour would be $5-8k (50-60 hours at $80-90/hour). Others on here have done their own builds so should be able to confirm what parts and machining cost. I can look after it till you get back...... nice try Quote Link to comment Share on other sites More sharing options...
clutch-monkey Posted 27June, 2014 Report Share Posted 27June, 2014 Why not go with ITB's if you're planning to run some higher duration cams etc? looking at the cams he's chosen they should work fine with the stock induction (i have RS/Cup cams or something in mine). ITB's would be nice but it's icing on the cake haha Quote Link to comment Share on other sites More sharing options...
sydr Posted 28June, 2014 Report Share Posted 28June, 2014 Funny you mention that! Waiting on a price on GT3 plenum and ITBs like on Sydr's car but think I might be a bit exxy. Don't worry about what it costs, close your eyes, pay up and enjoy. Worth every razoo Gman993 1 Quote Link to comment Share on other sites More sharing options...
Harvs11 Posted 29June, 2014 Report Share Posted 29June, 2014 I've just caught on to this build. I like where it's headed. A good tip for anyone pulling down an air cooled 911 is shown in a couple of your pics. Mark your cylinders with an engraver. This way you can put them back in the same order and avoid machining to match deck heights. And my 2 c on the colour, original grey is beautiful, but if you're going for coloured highlights then a solid or even matte grey is a winner. Quote Link to comment Share on other sites More sharing options...
Flatout Posted 1July, 2014 Report Share Posted 1July, 2014 Another fan of this build, keep us updated. Quote Link to comment Share on other sites More sharing options...
JV911 Posted 2July, 2014 Author Report Share Posted 2July, 2014 In the nude... Quote Link to comment Share on other sites More sharing options...
JV911 Posted 2July, 2014 Author Report Share Posted 2July, 2014 P0RN! 355 & 328mm Brembos Gman993 and Simonoz 2 Quote Link to comment Share on other sites More sharing options...
JV911 Posted 2July, 2014 Author Report Share Posted 2July, 2014 Before and after...clean as a whistle! Simonoz 1 Quote Link to comment Share on other sites More sharing options...
JV911 Posted 3July, 2014 Author Report Share Posted 3July, 2014 more goodies - Bilstein PSS10 Chris-p 1 Quote Link to comment Share on other sites More sharing options...
JV911 Posted 9July, 2014 Author Report Share Posted 9July, 2014 Don't worry about what it costs, close your eyes, pay up and enjoy. Worth every razoo Well the deed is done. Pulled the trigger on the ITBs Considered Mahle 3.8 P&Cs too but the price was getting eye-watering. Engine build summary: Blueprinted and balanced ARP rod bolts ARP head studs High comp 3.6L pistons Sport cams (custom grind) Titanium valve springs and retainers 993 RS valves Ported heads Rothsport ITB kit (Jenvey ITBs) Motec M84 ECU and Sensors Bosch injectors GT3 oil pump Billet rocker covers Pauly, clutch-monkey and Russ 3 Quote Link to comment Share on other sites More sharing options...
Pauly Posted 9July, 2014 Report Share Posted 9July, 2014 How much larger are the vales than stock? Quote Link to comment Share on other sites More sharing options...
JV911 Posted 9July, 2014 Author Report Share Posted 9July, 2014 49 v 51.5mm (intake) and 41.5 v 43.5 (exhaust) Pauly 1 Quote Link to comment Share on other sites More sharing options...
JV911 Posted 9July, 2014 Author Report Share Posted 9July, 2014 The Rothsport set-up Peter M, Simonoz, Pauly and 1 other 4 Quote Link to comment Share on other sites More sharing options...
clutch-monkey Posted 9July, 2014 Report Share Posted 9July, 2014 jesus.. i'll be back in a bit. going to go shake out my shed for anything i can sell for that.. Pauly 1 Quote Link to comment Share on other sites More sharing options...
JV911 Posted 9July, 2014 Author Report Share Posted 9July, 2014 Can get you a good price for a kidney Quote Link to comment Share on other sites More sharing options...
Hughesy Posted 9July, 2014 Report Share Posted 9July, 2014 this is an amazing journey thanks for sharing and inspiring hughesy Quote Link to comment Share on other sites More sharing options...
JV911 Posted 9July, 2014 Author Report Share Posted 9July, 2014 One more for tonight. Rennline quick release: Quote Link to comment Share on other sites More sharing options...
sydr Posted 9July, 2014 Report Share Posted 9July, 2014 Well the deed is done. Pulled the trigger on the ITBs Considered Mahle 3.8 P&Cs too but the price was getting eye-watering. Engine build summary: Blueprinted and balanced ARP rod bolts High comp 3.6L pistons Sport cams (custom grind) Titanium valve springs and retainers 993 RS valves Ported heads Rothsport ITB kit (Jenvey ITBs) Motec M84 ECU and Sensors Bosch injectors GT3 oil pump Billet rocker covers Now why does that look familiar? Quote Link to comment Share on other sites More sharing options...
JV911 Posted 18July, 2014 Author Report Share Posted 18July, 2014 Any ideas for alternative reverse lights once the rear reflector is replaced/painted? I was thinking maybe it could be rewired so that both indicators come on but open to suggestions. Quote Link to comment Share on other sites More sharing options...
FlatSix Posted 18July, 2014 Report Share Posted 18July, 2014 Any ideas for alternative reverse lights once the rear reflector is replaced/painted? I was thinking maybe it could be rewired so that both indicators come on but open to suggestions. You could always leave the reverse lights unpainted. I tinted my lights with some nightshade red yesterday and masked off the reverse lights for the first few coats. They look great. I'm sure I've seen the center piece painted with the reverse lights still exposed somewhere. Quote Link to comment Share on other sites More sharing options...
JV911 Posted 18July, 2014 Author Report Share Posted 18July, 2014 Any pics of yours? Are you thinking of the Ruf ones? I'm not really a fan http://forums.pelicanparts.com/uploads13/L10406591216053167.jpg Quote Link to comment Share on other sites More sharing options...
FlatSix Posted 18July, 2014 Report Share Posted 18July, 2014 I might be thinking of the ruf piece but I'm sure I've seen it with the reverse lights with the reddish stock tint. I'll be posting something up about my lights soon. I decided they were not as glossy as I would like. Just wet sanded and gave it a few more clear coats. Once they back on the car I'll make a post. Quote Link to comment Share on other sites More sharing options...
