993 Windscreen replacement
au-yt
I was wondering what experience ,if any, people have had when they had a 993 Screen changed?
I spoke the guys a ZAG and they mentioned that the aftermarket screen are missing a vital piece around the screen that holds the outer seal/trim in place.
I also found this article about 993 screen replacement.
http://www.glasstecpaul.com/problems-with-a-porsche-993-windscreen/
Cheers
Graeme
Beware there are aftermarket screens on Ebay for 385 that you could use in despiration however as 993 are now attracking collectors the correct screen is important.
Some where there is 10.... 993 with aftermarket screens.......
I found this out after I bough a screen thinking you beauty a replacement screen only $385. 0nly to dicover it doesnt have the plastic beading. Full marks to the guys I spoke to at the Auto Glass ware house in Queensland where i paid for the screen for organising for listening to m concerns and will I believe organise a refund next week.
They also mentioned that the screens are now being made in China ( how would have guessed) and they will look into this missing bead for future screens. I hope they go ahead and get it organised as the original screens are $1,500.00 plus..
Cheers
Graeme
993 front windscreen replacement is a dark art which seems to be mastered by very few windscreens techs.
There is an extensive section in the factory manual clearly outlining the steps required and the use of factory jigs to allow the correct positioning of the screen in sideways location and depth.
I am currently trying to arrange a screen to be replaced under insurance and am expecting some resistance to a genuine screen due to the cost, however this is not a Hyundai and seems to be an appreciating asset these days, so the argument may be long and drawn out!
The reality is that even the most experienced windscreen installer can have difficulty with the 993. Bugger!!!
I had a thought that I wish I had had before mine was replaced, before screen is taken out, remove rubber and make 4 curved blocks out of MDF or something similar to fit snugly between the screen and the body in the corners ,mark blocks and body and whilst glue is still wet slide blocks back into place to ensure correct placement of screen
Moran glass in Brisbane make windscreens locally (well at least they did 5-6 years ago when I visited their factory) I just got a screen from them fitted to my car, might be worth seeing if they do a 'correct' 993 screen?
Moran Motor Glass
136 Ingleston Rd, Wakerley QLD 4154, Australia
07 3390 8855
The glasstecpaul article helps demystify the installation process. And I am glad I discovered the issues before I got trapped. I really want to preserve this car so getting the correct info is important. Hint with insurance companies is make sure all the parts are on one bill and not listed separately.
Cheers
Graeme
Cheers
Graeme
  • 1 month later...
Car is going to my panel shop on Monday and while the screen is out I'm having some rust in the scuttle sorted, which is a standard 993 issue.
Insurance company has sprung for a genuine screen, which is commendable, but I must say that I'm really worried about the screen fit.
Heard too many horror stories and seen a couple of badly fitted screens. The 993 seems to be the most difficult P-car of the lot for screen fitting.
"Porsche" recommended guy had never heard of the factory jigs for installation, so I'm arranging for a set for him to use. All he needs to do now is read the manual!!!
Fingers crossed.
You may have some luck with the scratchs, provided they are light. Micro pitting forget it.
The scratches are as if someone tried to clean the window and the dirt was abrasive.  The scratches cannot be felt when you run you nail across them, but they restrict visibility when the sun is a certain angles.
I'm not worried about the pitting.
  • 2 years later...
