clutch-monkey Posted 23April, 2015 Report Share Posted 23April, 2015 That's cup cars. Completely different kettle of fish. Link to comment Share on other sites More sharing options...
turboT Posted 23April, 2015 Author Report Share Posted 23April, 2015 That's cup cars. Completely different kettle of fish.yep - money to burn:) Link to comment Share on other sites More sharing options...
michel Posted 23April, 2015 Report Share Posted 23April, 2015 Mr fish you have my mobile give me a call when you can..ps don't worry about the carbon Link to comment Share on other sites More sharing options...
turboT Posted 23April, 2015 Author Report Share Posted 23April, 2015 Mr fish you have my mobile give me a call when you can..ps don't worry about the carbon Just pm'd you Link to comment Share on other sites More sharing options...
michel Posted 23April, 2015 Report Share Posted 23April, 2015 I have a roll cage in some of my road cars- the bracing and protection is worth it. 60k per event, you'd be thinking of targa Tasmania maybe.. Not normal track events. Even Bathurst historics is less than a tenth of that iirc Me early minis had half and full roll cages - thought it essential bit of safety kit and mine were 99% road use Link to comment Share on other sites More sharing options...
09ELF Posted 23April, 2015 Report Share Posted 23April, 2015 rare as beez nuts, but these exist. Just get it in carbon... probably still not as strong as a coupe unless properly engineered Link to comment Share on other sites More sharing options...
turboT Posted 23April, 2015 Author Report Share Posted 23April, 2015 rare as beez nuts, but these exist.Just get it in carbon... probably still not as strong as a coupe unless properly engineered can you lend us yours so i can make a copy?? Link to comment Share on other sites More sharing options...
09ELF Posted 23April, 2015 Report Share Posted 23April, 2015 BAM.. crowd fund business idea. Link to comment Share on other sites More sharing options...
Coastr Posted 23April, 2015 Report Share Posted 23April, 2015 I was talking about the entire 1/4 panel and roof. Yes, Singer use the window frames and the inside panels. If you were making a targa/cab conversion you'd have to make the window frames as well. See here in video: http://www.youtube.com/watch?v=fJQ4hQSusjE?t=1144 The difference with the above is that you would bond to the frame directly. Or maybe you mold steel tabs into the carbon and then weld those. I have no idea how it's done, but it's entirely possible and my point about the manufacturers is that they are bonding carbon and steel together as well. Link to comment Share on other sites More sharing options...
Russ Posted 23April, 2015 Report Share Posted 23April, 2015 BAM.. crowd fund business idea. damnit, i've been searching for one of these for a while to do exactly this (reproduce them in carbon and CF) they connect into the rear demister too Link to comment Share on other sites More sharing options...
withers Posted 24April, 2015 Report Share Posted 24April, 2015 This is a good idea!! Are the roof dimensions of the SC, Carrera and 964 all the same? One design/build for all? Link to comment Share on other sites More sharing options...
poli84 Posted 24April, 2015 Report Share Posted 24April, 2015 D Morris Styling already makes these hard tops. http://www.dmoris-styling.com/eng/911-964-993-hardtops---photos-.html Link to comment Share on other sites More sharing options...
withers Posted 24April, 2015 Report Share Posted 24April, 2015 D Morris Styling already makes these hard tops. http://www.dmoris-styling.com/eng/911-964-993-hardtops---photos-.html That website is awful! And anyone know how much? Certainly looks tidy on the 964. Link to comment Share on other sites More sharing options...
michel Posted 24April, 2015 Report Share Posted 24April, 2015 Amanda they all fit you'll also remember the NZ car I sent you links to last yearish white cab with blk special wishes steel hardtop ... Russ you could have bought the lot for less than 25k Link to comment Share on other sites More sharing options...
withers Posted 24April, 2015 Report Share Posted 24April, 2015 Cool cheers Michel. I'm starting to forget what I've learnt. Link to comment Share on other sites More sharing options...
edgy Posted 25April, 2015 Report Share Posted 25April, 2015 With the market the way it is buying a cab and putting a roof on it is really starting to make financial sense! Link to comment Share on other sites More sharing options...
Peter M Posted 25April, 2015 Report Share Posted 25April, 2015 Good info on the Moris hardtops on Rennlist: http://rennlist.com/forums/993-forum/476417-hard-top-993-a.htmlThere is a better one I recall that followed the installation but can't find it at the moment! Link to comment Share on other sites More sharing options...
930 Posted 25April, 2015 Report Share Posted 25April, 2015 Putting a hardtop roof on a cab car need not add any great structural rigidity but it will add some nonetheless.If it was a Cab previously then the floorpan/chassis has been reinforced anyway, this is how they are able to maintain rigidity whilst driving without a roof on.An Early Coupe roof say from a 74 without sunroof only weighs about 10kg, it will lower the centre of gravity to nearly equal that of a cab car, the difference between that and of carbon would hardly be noticeablewouldn't it?Any years from between 74 to 89 can be swapped and matched to existing panels easilyA 930 with the 917 based brakes and reinforced floorpan with a hardtop would be tight as a drum and handlebetter than a stock 930 coupe would.My father did similar, he bought a 930 that had been converted to a CAB by a PO, so he got it very very cheap, (cheaper than a 911sc)he took away the cab part and welded a 1974 roof on the car, as it is without sunroof and the earlier panel being lighter than later ones the centre of gravity was (greatly) increasedTotal cost of conversion back to coupe was about $500 Link to comment Share on other sites More sharing options...
930 Posted 25April, 2015 Report Share Posted 25April, 2015 Plus many hours of elbow grease ill add Link to comment Share on other sites More sharing options...
hugh Posted 25April, 2015 Report Share Posted 25April, 2015 Note: this is why checking vin and delivery details is so important people. Link to comment Share on other sites More sharing options...
