Carrera86 Posted 3May, 2015 Report Share Posted 3May, 2015 I am trying to replace the felt seals , front one is straight forward but the back one is the issue , do you have to remove the sunroof or can it be done in place , the new seal for the rear also looks a bit thinner than the one that is there at the moment . Link to comment Share on other sites More sharing options...
Peter M Posted 3May, 2015 Report Share Posted 3May, 2015 Yes, to replace the back one you need to remove the sunroof panel. But it is ingeniously simple and if you Google it there are some good threads with pictures on Rennlist and Pelican that show you step by step. Link to comment Share on other sites More sharing options...
Stew F Posted 3May, 2015 Report Share Posted 3May, 2015 I've been looking at replacing my seals as well. Here's a how to from PP. Seems pretty easy. http://forums.pelicanparts.com/porsche-911-technical-forum/376404-sunroof-cable-repair-new-seals-87-911-a.html Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 20August, 2018 Report Share Posted 20August, 2018 So when getting a car painted, and the seals need to be replace, which are the seals and part numbers required? I'm not meaning to sound lazy, but when I look a the parts diagram, there are a tonne of parts, and I'm not too sure what is needed? Car is a 1977 911. The parts I have ordered are 911 564 409 00 911 564 191 00 911 564 193 00 911 564 465 00 Any guidance always appreciated Link to comment Share on other sites More sharing options...
81SC Posted 20August, 2018 Report Share Posted 20August, 2018 Mike, most times (not always) the seal has a profile view on the parts diagrams. See no.s 15,16, 48 & 49 have the profile view in the attached circle. Link to comment Share on other sites More sharing options...
