Whats the hotness in track torsion bar suspension setups??
Teutonic
So I am looking to try to first optimise the torsion bar setup on my 74 widebody 911. (Or stop me here and tell me to ditch it in favour of coilovers :) )
I have a little more work to do taking stock of what the car currently has but have spotted a few things...
Koni Yellows (sport) at the rear but the fronts are different so unknown. Maybe there is a better option here?
Adjustable sway bars. Receipt tells me an 18mm and 20mm, Part number suggests from Performance 9.
Torsion bars...based on receipts I have a 23mm (performance 9 based on part no.) and a 30mm "sway-away" tubular on the rear. (based on the part number)
Turbo tie rods
Adjustable spring plates (performance 9??)
Have installed an elephant racing bump steer kit up front.
Have on the shelf and yet to install their quick camber kit up front.
That's about where it is currently. Any input on how it might be improved are appreciated.
EDIT: Re usage it is track focus with some street driving but happy to compromise daily duties for track performance.
Dude what are you actually asking? You've got a track biased ride by what your describing?
you've actually done laps in the wee beastie? that's where i'd begin and tap into some local knowledge - plenty who'll want to joy ride.
 I'd also  figure out what the front shocks are. 30mm rear t-bars are mighty - not much fun on the roads I drive
hope youre mainly doing track time - if not jail time
Sort out front shocks  - make sure frnt and rear are working well
make sure all bushes balls and tie rods are peachy - makes a big difference.
If you want to go cool over rebel elephant make all the kit you need.
if you want to get a woodie look on elephant racings site
talk to some race shops
I have 23 and 31 in mine with stock sway bars. Have only had it at the track once. It felt neutral.
You can get 24 fronts and up  to 36 rears. Or you can get what you want custom made. I think Performance 9 can do them.
Maybe try 24 front and 33 or 34 rear. That would be like 290 front spring and a 430 or 490 rear. Not that stiff really.
My understanding is the more rear tyre you have the stiffer you can go at the back.
Thanks Gents
appreciate the input. I guess the question I was asking is, with other platforms I have played with, there is generally a well trodden path for good track suspension setup that can still be driven on the road. Obviously each individual has their own idea of what they consider tolerable on the road, and which brands they prefer, but there are some pretty widely used ride heights, spring rates, camber settings etc. Just didn't want to go and reinvent the wheel.
Have had a closer look up front and it runs Koni sport as well. So sounds like what is already under the car is a reasonable starting point. I certainty don't find it bothersome to drive on the road, just need more track time.
Have some new r comps on the way (295 rear 235 front ) so might as suggested just go over it and make sure what is there is all in good working order, get a good alignment into it and get some track time and see if there are any major shortcomings.
Cheers for the input.
