ByronBayChris Posted 8October, 2015 Report Share Posted 8October, 2015 Pretty simple. Was driving OK, then a petrol smell started to creep in to the cabin. Going up a slight hill, and the engine just cutout. All lights came on and the car rolled to a halt.Tried to restart - car would crank but not stay running. After 20 minutes, it would start and kick over for 2 seconds. Then stop again.Has been towed to Stokers VW where we will get it on the hoist tomorrow.Fuel pump ? Link to comment Share on other sites More sharing options...
Russ Posted 8October, 2015 Report Share Posted 8October, 2015 fuel pump relay? fuel pump? fuel lines?can you hear the fuel pump working? wiggle the relay in it's socket or swap it for another known good one of the same sizeall a guess based on the fuel smelldo you have a diagnostic computer to plug it into? Link to comment Share on other sites More sharing options...
James P Posted 8October, 2015 Report Share Posted 8October, 2015 +1 to the above Link to comment Share on other sites More sharing options...
ByronBayChris Posted 8October, 2015 Author Report Share Posted 8October, 2015 fuel pump relay? fuel pump? fuel lines?do you have a computer to plug it into?I never got my OBDI cable working. I gave up , but should have persevered. Especially for cases like this.Im hoping Stokers has one. Link to comment Share on other sites More sharing options...
twood Posted 8October, 2015 Report Share Posted 8October, 2015 I have a spare fuel pump relay that you can borrow if you are here on Sunday Link to comment Share on other sites More sharing options...
Steiny Posted 8October, 2015 Report Share Posted 8October, 2015 I'm familiar with 'that petrol smell creeping into your cabin' Chris. Funny.I'm completely unhelpful I know... Link to comment Share on other sites More sharing options...
L999 Posted 8October, 2015 Report Share Posted 8October, 2015 Def sounds like a fuel pump / fuel line issue. Check whether you can hear the fuel pump when the car is on reds.Check your fuel lines running from the fuel tank to see if they are cracked or leaking or letting air into the system. Link to comment Share on other sites More sharing options...
ByronBayChris Posted 8October, 2015 Author Report Share Posted 8October, 2015 Also going to rig up a jumper for the DME and see if I had a dead spare. Found this on Pelican.In an absolute roadside emergency, you can wrap a paper clip around terminals 87, 87b and 30 and reinsert the relay long enough to get the car to a safe location. This is NOT a substitute for a proper relay. If you have a paper clip on you, then you should have had an extra relay or two in the fuse box, which you should use instead of this MacGyver approach.Agree about having a spare DME, however a spare paperclip is known to work and not be faulty also. Link to comment Share on other sites More sharing options...
ByronBayChris Posted 9October, 2015 Author Report Share Posted 9October, 2015 So, swapped out to the spare DME. Nothing.Made a harness and jumped the three sockets for the DME. Nothing.Wrapped the paperclip around the DME terminals (87, 87b, 30). Nothing.DME had power coming out of it.Connected a power source to the fuel pump.....and it pumped, so that was ok.About to run a cable from pin 87b on the DME to the fuel pump.Checked under the fusebox - WTF - the immobiliser (as always) was installed by a chimpanzee from a remote jungle who had never had the opportunity to discover what happens when a wire is squashed between a fuse box and a metal car. It was melted. Cleaned it up and the car started and ran.Phew, but now I do carry a paperclip with me as well as a spare DME relay.And only took three hours of time. Not too bad. Link to comment Share on other sites More sharing options...
firstone Posted 9October, 2015 Report Share Posted 9October, 2015 Gotta love those after market installers.Good to hear you have it sorted. Link to comment Share on other sites More sharing options...
Harvs11 Posted 9October, 2015 Report Share Posted 9October, 2015 We'll done,Chris. You got off cheap. One of the rare times my car "failed to proceed" I had to pay hourly rates to have the chimp's immobilizer work purged from my wiring harness. Link to comment Share on other sites More sharing options...
