monty188 Posted 11November, 2015 Report Share Posted 11November, 2015 My ignition switch is definitely worn. It looks all it needs are new tumblers.Where is the best place to get a new switch?. What the process for changing over to the new switch ? Do I need to visit my local Porsche Dealer ($$$$ shudder) Can a replacement switch match my existing key?The Bentley manual is decidedly light on details. Link to comment Share on other sites More sharing options...
Coastr Posted 11November, 2015 Report Share Posted 11November, 2015 Switch and lock are two separate pieces. You want the lock, which was $1500 last time I checked. Switch plugs into the back of the lock and is $150. It will not match your existing key and comes with a new key. You would have to get your other locks rekeyed to match.101 projects for porsche 911 has a section on rekeying but I understand the kits are NLA. Not sure if a specialist auto locksmith can refurb based on generic parts or not. Something on my todo list because I have mismatching door/ignition key locks. Link to comment Share on other sites More sharing options...
Dreamr Posted 11November, 2015 Report Share Posted 11November, 2015 I also have 2 x separate keys Coastr .... I'm not sure why, but I thought they were delivered like that? Link to comment Share on other sites More sharing options...
Coastr Posted 11November, 2015 Report Share Posted 11November, 2015 If you read Wayne's book multiple keys are common but not original. The ignition locks can and do fail (I had to bodge mine after receiving sticker shock), plus door locks get the old 'hammer and screwdriver' treatment when someone leaves $2.75 in loose change in the console.i would have three keys if I actually had one for the passenger door. Link to comment Share on other sites More sharing options...
Russ Posted 11November, 2015 Report Share Posted 11November, 2015 I also have 2 x separate keys Coastr .... I'm not sure why, but I thought they were delivered like that?is one red and one black? red is usually the valet key that doesn't unlock the glovebox (or boot if you have the locking mechanism option) and black does everything Link to comment Share on other sites More sharing options...
TE911 Posted 11November, 2015 Report Share Posted 11November, 2015 My ignition switch is definitely worn. It looks all it needs are new tumblers.Where is the best place to get a new switch?. What the process for changing over to the new switch ? Do I need to visit my local Porsche Dealer ($$$$ shudder) Can a replacement switch match my existing key?The Bentley manual is decidedly light on details.Hi Monty,We had the same issue, had to have the lock replaced.I rang BWA Auto and they had a new lock for $1200. But John at ZAG automotive has second hand ones with the key for about $500.I got ZAGs lock barrel and had my mechanic send it to a locksmith so it would work with my original key. Works great now!You dont need to have your other locks rekeyed just send the new lock barrel and your original key to a locksmith of your choice.Just give John from ZAG automotive a callhttp://www.zagautomotive.com.au/contact/Hope this helps. Link to comment Share on other sites More sharing options...
Stew F Posted 11November, 2015 Report Share Posted 11November, 2015 I've seen tumbler kits on ebay recently. Any competent locksmith should be able to make it all come together. Link to comment Share on other sites More sharing options...
T-Man Posted 11November, 2015 Report Share Posted 11November, 2015 Suffered with this some 3 years ago. Key would get stuck and not turn. Very concerning when you are far from home. Brake cleaner and lock lube. No issue since. http://www.callasrennsport.com/wp-content/uploads/2011/01/Ignition-Locks.pdf http://rennlist.com/forums/993-forum/578085-ignition-switch-lock-stuck.html Link to comment Share on other sites More sharing options...
Dreamr Posted 12November, 2015 Report Share Posted 12November, 2015 is one red and one black? red is usually the valet key that doesn't unlock the glovebox (or boot if you have the locking mechanism option) and black does everythingI do have 1 x black key with the little light in it (not working anymore) and just a standard key.The black one does the doors, and the "normal" key is the ignition.I thought this was standard .... now I find out otherwise. Link to comment Share on other sites More sharing options...
Russ Posted 12November, 2015 Report Share Posted 12November, 2015 I do have 1 x black key with the little light in it (not working anymore) and just a standard key.The black one does the doors, and the "normal" key is the ignition.I thought this was standard .... now I find out otherwise.i'm not saying it's gospel (and it could be only later cars) - but i thought the red/black was itRed ones available pretty reasonably here:https://www.fcpeuro.com/products/porsche-key-blank-914-911-912-74443007001Most locksmiths should know how to manufacture the different options from your key code Link to comment Share on other sites More sharing options...
Coastr Posted 12November, 2015 Report Share Posted 12November, 2015 Hi Monty,We had the same issue, had to have the lock replaced.I rang BWA Auto and they had a new lock for $1200. But John at ZAG automotive has second hand ones with the key for about $500.I got ZAGs lock barrel and had my mechanic send it to a locksmith so it would work with my original key. Works great now!You dont need to have your other locks rekeyed just send the new lock barrel and your original key to a locksmith of your choice.Just give John from ZAG automotive a callhttp://www.zagautomotive.com.au/contact/Hope this helps. what was the cost of rekeying the lock? Did it take long, and are there specialists or any old locksmith can do it?i have proper porsche blanks ready to go, and I already know how to pull out the lock. Link to comment Share on other sites More sharing options...
TE911 Posted 12November, 2015 Report Share Posted 12November, 2015 what was the cost of rekeying the lock? Did it take long, and are there specialists or any old locksmith can do it?i have proper porsche blanks ready to go, and I already know how to pull out the lock.It shouldn't cost more then $100 im pretty sure any locksmith can do it but i got my mechanics locksmith to do it.Your best bet is to call a locksmith and ask. Link to comment Share on other sites More sharing options...
michel Posted 13November, 2015 Report Share Posted 13November, 2015 Typically not a job for mr minit, any competent shop can do it. There are also some great threads on pelican for the diyer.PS I had to replace my lock a month ago. $250 Link to comment Share on other sites More sharing options...
