Steering wheel play/slop? Help needed!
Dsisco
Hey guys,
I have just purchased another 911SC,
The problem I have is that for some reason the steering has some play/slack,
For some reason the steering is easier to turn left & is hard to turn right,
any idea where to start? could it be an alignment issue? Tie rods?
Any help would be much appreciated
can you physically move the wheel up and down etc? the plastic bearing is a common issue, pelican sells a much better replacement (the mitch leland bushing).
it's what i'd check first
yes you could before, I just fitted the Mitch bushing which has helped, but still does it,
ill be upgrading to the turbo tie rods this week & get it aligned hopefully that fixes it
  • 2 weeks later...
