Narrow Body, Wide Body wheel options and sizes!
Owgasm
Hi guys,
I've been really itching lately to get a new set of wheels to fill the guards perfectly.
Car is a 964 C4, with a 993 Turbo S kit. So a Widebody NB.
I know there are a few Widebody NB out there, what wheels are you running and at what size and offset?
Thanks in advance for your help! My last resort is ordering SSR or Work wheels at the desired sizes. I'm currently leaning towards building a set of 3 piece wheels. Just have to find the right wheel/design and at 5x130!
Car is in Brisbane and if there's anyone local that has wheels in sizes that would suit, I'd love to try them on to gauge what size and offset I need or even a starting point to push it further or not :)
Feel free to post up photos of other cars around the world :) would love some inspiration
Thanks. I understand how offset works.
Just wanting to see what options I have, to perhaps get a good base off and then tinker with the measurements for the desired fitment.
Also to see what other Widebody NB owners run :)
From a previous post I made, hope it helps
Wheel Fittment Chart
Front Fittments: Wheel Offsets Max Tire Notes:
911 Narrow 70-89 7x15 10.8, 12.5, 23 225/50/15 Easy
7x16 10.8 225/50/16 Tight 911 Offset
7x16 23 225/50/16 Medium 951 Offset
6x16 12.8 205/50/16 Tight 930 hubs on narrow body or 19mm spacer
8x16 53 225/50/16 Easy 930 hubs on narrow body or 19mm spacer
7.5x17 23 205/50/17 Easy
7.5x17 23 225/50/17 Tight
7.5x17 53 235/45/17 Easy 930 hubs on narrow body or 19mm spacer
8.5x17 53 235/45/17 Easy 930 hubs on narrow body or 19mm spacer
9x17 53 245/40/17 Medium 12.5-19mmmm spacer
7.5x18 53 225/40/18 Tight 12.5-19mmmm spacer
8x18 53 235/40/18 Tight 12.5-19mmmm spacer
911 Wide 70-89 8x15 10.8, 12.5 225/50/15 Easy 930 hub or 911 hub -w- 19mm spacer.
7x16 12.5 225/50/16 Easy 930 hub or 911 hub -w- 19mm spacer.
8x16 12.8, 23 245/45/16 Easy 930 hub or 911 hub -w- 19mm spacer.
9x17 23 255/40/17 Easy 930 hub or 911 hub -w- 19mm spacer. 930 Rear
10x17 23 275/40/17 Tight 930 hub or 911 hub -w- 19mm spacer.
10x18 40 285/30/18 Tight 931 hub or 911 hub -w- 19mm spacer. 993TT Rear
964 Narrow 89-94 8x16 53 225/50/16 Easy
9x16 53 245/45/16 Very Tight
7.5x17 53 225/45/17 Easy
8.5x17 53 235/45/17 Tight
9x17 60 235/45/17 Tight 1/4" Spacer
993 All 95-98 7x16 53 225/50/16 Easy 951F
8x16 53 225/50/16 Easy C2/951 Rear
9x16 70 245/45/16 TIght 993-16" rear
7x17 53 225/45/17 Easy 993/C2 Cup
8x17 53 235/45/17 Easy RSA Rear
9x17 53 245/45/17 TIGHT 993/C2Cup Rear
Rear Fittments: Wheel Offsets Max Tire Notes:
911 RS, S, Carrera 7x15 12.5, 23 225/50/15 Tight Fuchs
8x15 23 245/50/15 Tight 911/944 rear
7x16 10.8/23 225/50/16 Easy Fuchs
8x16 23 245/45/16 Easy Fuchs or 951 Rear Phone
9x16 23 245/45/16 Easy Fuchs
8x16 53 245/45/16 Easy Use 30mm 1"-1.25" Spacer 951 Late or C2
9x16 70 245/45/16 Easy Use 50mm-2" Spacer 993 Rear
9x17 23 275/40/17 TIGHT May use 255/40/17, depends on car Aftermarket C2/993 Knockoff
9x17 53 275/40/17 Med Use 23mm Spacer Watch inner fender/Oil Lines
10x17 23 275/40/17 Very Tight Aftermarket, Borbet/HRE etc.
10x17 53 275/40/17 Depends on car Use 23mm-1" Spacer
10x18 40 285/30/18 Very Tight No spacer to 1/4" 993TT wheel
10x18 65 285/30/18 Very Tight 1.5-1.75" spacer
911 Wide All up to 11 wide
23mm or add spacers
12x17 Easy 315/35/17
12.5x17 Carefully! 335/35/17
12x18 Carefully! 335/30/18
964 Narrow 89-94 8x16 53 245/45/16 Easy Stock wheel with upside tire
9x16 70 245/45/16 Med 993 16" wheel
9x17 53 255/50/17 Easy 965 / 993 Cup wheel
9x17 53 275/40/17 Tight 965 / 993 Cup wheel
10x17 53 275/40/17 TIGHT
9x18 65 265/35/18 TIGHT 1/2" spacer needed to clear trailing arm Boxster wheel
10x18 65 285/30/18 Good Luck 1/2" spacer needed to clear trailing arm 993 twist or sportclassic II
993 All 95-98 9x17 53 275/49 17 Note lots of space to the inside. 993 cup
10x17 53 275/40/17
9x18 50 265/35/18 Med Boxster SCII
9x18 70 265/35/18 Easy Optional
9x18 65 265/35/18 Easy
10x18 65 285/30/18 Very Tight 285 is tight on 993, trick is to inset wheel. 993/996 fittment twist or SportClassic II
http://porscheforum.com.au/topic/4144-about-to-buy-wheels-need-offset-advice/#comment-66089
This might help.
Went through the same process but for wide bodied G series. Having some rims to actually test fit would have been nice :)  but ended up doing some very careful measuring off the wheels I had and taking a punt on offset. As far as manufacturers that will do a custom rim in a 5 x 130 you can try SSR, CCW and Forgeline that I know of. I don't believe Work do that stud pattern in their custom range.
I did some forgeline custom wheels on a previous car and they were able to email me a sectional drawing of the rim so I could use CAD (cardbord aided design) to make a full scale template and sit it on the hub face and get a feel for inner and outer lip positions. But I think having a wheel of known offset and size on the car and having the car on the ground on those wheels is a much better starting point for making calculations.
Thanks TE911.
If I'm reading correctly, the front of a 993/964 Widebody is no wider than a narrow body. At best a 18x8 +52 only? Yikes. Is that right?
However I do like the sound of a 18x12 with a 335 tyre. (I already have one of those laying around but at 5x114.3).
Great info in regards to options of wheels.
How different is a Widebody G series? What size wheels did you end up with and how was fitment in the end?
I do believe work are able to customize a 5x130, it is in their specification and size list if I recall correctly.
I am trying to find some wheels to work off, ones that a labeled or stamped. My current wheels give me false readings when I do the measurements haha.
Cant comment on the difference in available real estate for wheels between a wide bodied G series and what you have. But I was told the front fibreglass guards were mouIded off a 993 turbo and were a direct bolt on to my chassis. The rear is a glassed on guard as opposed to steel so no guarantee it is dimensionally perfect to say a steel turbo body. I finished up with 18 x 9 up front (-7 offset) and 18 x 11 at the rear - 32. Is a really nice fit. Fits very close to flush with the guards but have avoided any rubbing issues.
Work do the brombacher in a porsche fitment (5 x 130) with a reasonable amount of offset options. Just not full custom offset.
http://www.workwheelsusa.com/media/wheels/38/104/Brombacher_SPEC09A4.pdf
The coilovers take up a lot more real estate behind the wheels than torsion bars do.  So you'll get less dish than a torsion bar car if that's your goal.
Hard to comment on your fitment as it's a custom body.
I'd be looking CCW, rotiform, fifteen52, HRE and Work for custom offsets. BBS is also obvious but expensive (so are HRE).
Apparently CCW are very helpful over phone and email for fitment advice.
I've also heard good things about this crew for work wheels:
http://www.jdmconcept.com.au
