You can keep your Singer
Airhead
As the title says-
Try this for size.
RUF SCR 4.2
12802926_10154616620362468_4749264336914
12814729_10154616620447468_2819228913821
12806261_10154616620547468_6072017190040
Technical Data / technical data
Power / power
525 HP / 386 kw at / @ 8.370 / min
Max. Torque / torque
500 NM at / @ 5.820 / min
369 lb ft
Engine Size / displacement
4.185 cc
Transmission / transmission
6-speed manual transmission
Maximum Speed / top speed
322 km/h
200 mph
Dimensions & weight / Dimes the & weight
Din / notch unladen weight din 1190 kg
Radstand / Wheelbase 2342 mm
Leistuntgsgewicht / Power-weight ratio 3,09 kg / KW / 2,27 kg / PS (HP)
Consumption / fuel consumption
Urban / Urban 19,8 l / 100 km
Except Urban / Non-Urban 10,4
l/100km
Total / combined 13,9 l / 100 km
Co2 emissions / Co2 emissions 329 G / km
Efficiency / efficiency class g
Would have loved it if it was still Air /Oil cooled There is enough water cooled fast cars about already ;)
You can still buy old Ruf cars.
The fast cars are a bit , well , overdone. Even the autobahns are speed limited for the most part. Which track would you take it to? Who would?
But these bespoke cars help fill the void for the "mine's bigger than yours" gent ;)
Good luck getting past the Priuses on the Nurburgring I reckon.
Is there an AC/DC plaque on the back Harvs?
Proper sewing machine that one. Not one of these new fangled thermomix types.
I guess tazzie you'd consider my sewing machine a gt3 then...with PDK, PASM, PSM, PDCC, PCM, ETC!
AC-DC?  Sure is.  I never noticed that before.
That's about as high tech as this one gets.  It's built for straight lines and the occasional curves. Just how I like 'em.   I believe it will still be running well after we're all off this rock, not like the modern stuff.
That must be one of them moderen ones full of lectronomics n stuff.  I still got the analog version with a CIS (Crank It System).  No fancy stuff and you can work on it yourself
C'mon Trev , this is how it's done by real sailors
Believe me it's harder than it looks. It'll turn anyone AC/DC for hours on end.
3 strand...easy!  And this is how it's done by real arborists....in 24 strand cover over 16 strand core doublebraid rope!
Hand splicing is an art we practice daily ;)  Easy when you know how.  This rope takes about 30 mins.
Like most things! Even surgery isn't rocket science. A good eye , steady hand and ability to avoid stuff ups are admirable qualities.
So you do or don't use electronic sewing machines?
Splicing mooring ropes is more my experience. Like working on your own brakes , there are consequences for doing a poor job.
Now back to the Singer :D For those that don't know (and you should , being Aussies) ,  the singer of AC/DCs guitarist's sister named the band after spotting the moniker on the back of the machine she was sewing Angus' school uniform on.
This forum isn't just about avarice & lust you know.
