Headlight Recommendations & Immobiliser Options
Steve88
Hey guys just wondering if anyone has any good recommendations for headlight bulb upgrades for my SC .
Current visibility at night can be compared to driving with your eyes closed whilst wearing both a blindfold and sunglasses .
Looking for something that will be bright but also look period not keen on White light or blue if this makes sense at all .
Also in the progress of wiring up my foggies so any recommendations on bulbs for these it will also be greatly appreciated .
Furthermore looking to chuck in a new immobiliser as the current one is a mess and not great . Where did you buy it ? How much was it ? What brand is it ?
Many thanks
Steve
I am going to try these. Basically they just replace your current globes and give you Singer style head lights. You can then change your lenses with early clear VW ones as well if you want the full look.
http://www.ebay.com.au/itm/2X-MINI-2-5-HID-BI-XENON-PROJECTOR-LENS-KIT-HID-HEADLIGHT-SHROUD-H1-H4-H7-RHD-/171976059219?hash=item280a926953:g:HC8AAOSwl9BWKGE6
I have set of Philips X-treme Vision +130 in the 964, chalk and cheese difference.
Best place to get them is here, cheaper than any local auto shop. Remember to use the code for 20% discount.
http://www.powerbulbs.com/au/store/category/car-bulbs/fitting/h4-472
Thanks heaps will buy a set now .  These isn't an option to check the make and model of my car to make sure these will fit . But one would assume they should be the same bulb fitment ???
Fraz are the xTreme the latest release? Been hearing of a new bulb about to hit the market.
Btw check alternator function and upgrade your light harness to draw directly off battery via add relays
Will check this out many thanks
Steve with alt if dodgy you can usually have fixed and or improved ( output) based on auto elecs advice.
An alternate  if needing replacement is to buy the K3 from the manufacturer in QLD.
Have you checked the headlight aim is spot on? When I first picked up my 3.2, I could not tell if the headlights were on or off at night. The bulbs had been replaced by the previous owner in I assume an attempt to improve things. They were Philips X-treme. After I adjusted the headlight aim, I was very happy. Picture shows low beam
As far as immobilisers go. I drove a few cars years ago in which you needed to be touching a certain screw to earth it out, or the car won't start. One of my friends had the car broken into in the driveway and the thieves got in got it hot wired, but when it didn't start after 20 seconds it started beeping the horn, and they ran. Successful immobiliser in my eyes. I would look into something like that.
