Nicco Posted 1December, 2017 Report Share Posted 1December, 2017 Can anyone who owns a 996 4S or Turbo tell me the width at the front doors. The width is listed as 1830mm but presume this is at the widest point (rear). I have a small single garage and are trying to work out if I can fit it in and open the drivers door! Thanks. Link to comment Share on other sites More sharing options...
Jimmy Posted 3December, 2017 Report Share Posted 3December, 2017 Door width 1260mm, thats from left of door to front fender. Actual access opening to comfortably hop in and out is 730mm from edge of door to body. Hope this helps. Link to comment Share on other sites More sharing options...
Guest DG996c4s Posted 3December, 2017 Report Share Posted 3December, 2017 Hi Nicco, I have same narrow garage issue you explained and just recently acquired my 996 C4s. Attached is a few images and a dimension drawing of my situation. I'm 172cm tall and 75kg so not a big guy, I find the 320 mm gap for my door access just works for me. I have the left hand mirror gap of 140mm to save getting too close Hope this helps with your plans. Cheers Dennis PS: to make car width exact = 2450 less 140 & 370 = 1940 (outer mirror to outer mirror - unfolded.) Dennis Link to comment Share on other sites More sharing options...
Nicco Posted 9December, 2017 Author Report Share Posted 9December, 2017 Fantastic. Thanks for your he info. Link to comment Share on other sites More sharing options...
