Gadgeteer Posted 21June, 2020 Report Share Posted 21June, 2020 Hi all, i have a 2004 Cayenne Turbo that's been having air suspension problems ever since i acquired it. I guess previous owner gave up. I've replaced the compressor, valve block, air suspension controller from air struts and rear strut valves. i've finally managed to keep the vehicle from deflating totally whenever i switch off the engine. So far the air suspension operates as it should but i always have the yellow warning that air suspension needs service. Occasionally i still get the red air suspension fault warning. Could this be because i haven't calibrated the air suspension system yet?I use either a Launch x431 V+ or an Autel MaxiDAS DS808. But whenever i try to calibrate, they both stop midstream or do not proceed altogether. Am i doing something wrong?Your expert advice would be very helpful Quote Link to comment Share on other sites More sharing options...
