Ian Stacker Posted 13April, 2021 Report Share Posted 13April, 2021 My V6 has a slow coolant leak from the coolant temperature sensor housing. I’m trying to figure out whether I need to remove the inlet manifold to get to it. I can see 2 of the 3 bolts that hold it on but can’t see the 3rd. Has anyone done this job? Appreciate any heads up. Quote Link to comment Share on other sites More sharing options...
Ian Stacker Posted 3June, 2021 Author Report Share Posted 3June, 2021 no mate I'm about to start the job...hoping to not have to remove the inlet manifold...mine is leaking from 21 Quote Link to comment Share on other sites More sharing options...
Ian Stacker Posted 9July, 2021 Author Report Share Posted 9July, 2021 Yes I did fix it. Easy to reach it from under the car. Removed no 16 above, 3 bolts, 1 hose clamp and 1 hose clip (17). Then gently pull towards rear of car to remove from (9). Then replaced all o rings. No longer leaking Quote Link to comment Share on other sites More sharing options...
