Janek Krenc Posted 5March Report Share Posted 5March I have been making these RHD 911 panels exclusively for a well known Porsche restoration business in Victoria and will now offer them to anyone that requires high quality hand made products. Not limited to just the 911, if you have a part that's seen better days and needs replacing and you have a sample then I will do my best to help. This is not a quick fix solution. If the parts are available as after market then this will be a cost effective solution for you. Hand made takes time. I also have machining capabilities with lathe, Mill and surface grinder. The machining is secondary to the sheet metal work. Can also make for SWB. Call me.... Janek +61 408911993. Adelaide Australia. Quote Link to comment Share on other sites More sharing options...
