boslapet Posted 15October, 2009 Report Share Posted 15October, 2009 z Link to comment Share on other sites More sharing options...
funkysmell Posted 25May, 2011 Report Share Posted 25May, 2011 Hi Peter, Did you end up buying new wheels? I have the exact same situatiuon. 993 turbo that needs a new set of track day wheels/tyres. I heard Toyo888 work well. Hi, I need some advice on tyre sizes for my car.... any gurus out there? I have a 1996 993 turbo and I have bought a set of RH Cup (993 GT2-look) wheels, designed spcifically for the 993 turbo. Front: 9J x 18 ET52 - 10 inches rim-edge to rim-edge , Rear: 11J x 18 ET40 - more than 12 inches (31cm) rim-edge to rim edge. As you may know, 993 turbo Original Equipment wheel & tyre details are as follows: Front: 8J x 18 ET52 with 225-40-18 , Rear: 10J x 18 ET40 with 285-30-18 I have 3 questions: 1. What is the maximum width of tyre (front & rear) that I can fit on these wheels, on my unmodified car - obviously without clearance issues? 2. Could changing from the abovementioned standard tyre sizes cause issues with the 4wd system of my car (different front:rear circumference ratio)? 3. Given the answers to the above questions, what tyre sizes would you recommend I fit on these wheels? Thank you, Peter. Link to comment Share on other sites More sharing options...
Guest vas930 Posted 25May, 2011 Report Share Posted 25May, 2011 Hi Gents give Russell a call at Stuckeys in Brunswick 03 93865331 The Guru in my opinion. Good luck. Vas. Link to comment Share on other sites More sharing options...
