Mike 66 Posted 25March, 2018 Report Share Posted 25March, 2018 Hi Can you fit lhd headlight assemblies to a rhd car? The lever that narrows the beam is this acceptable for Australia authorities Or can the headlights be swapped over ? Lh side to the rh side? Or can you physically change the reflector? As the globes are the same? Or is only original rhd setup allowed? Thanks Link to comment Share on other sites More sharing options...
turboT Posted 25March, 2018 Report Share Posted 25March, 2018 4 hours ago, Mike 66 said: Hi Can you fit lhd headlight assemblies to a rhd car? The lever that narrows the beam is this acceptable for Australia authorities Or can the headlights be swapped over ? Lh side to the rh side? Or can you physically change the reflector? As the globes are the same? Or is only original rhd setup allowed? Thanks you need to get new reflectors. Can't swap Link to comment Share on other sites More sharing options...
