CHS Posted 3July, 2019 Report Share Posted 3July, 2019 I know its probably been covered before on here and other forums eg: rennlist , i tried going through it but my question is simply, Will a 17x7 and 17x9 e55 offset 996 wheel fit my 81 928 ? Link to comment Share on other sites More sharing options...
ANF Posted 3July, 2019 Report Share Posted 3July, 2019 Will they fit - most likely yes, although the offset is wrong for a 928. The fronts will push out 10mm from standard, this could have the affect of tramlining.... or it may not be noticeable? The topic of putting different offsets on a 928 is a touchy one, lots of arguments of what will and wont work.... The rears will push outwards 35mm, will this fit inside the guards, not sure? Also depends on what size tyres you run? Not a fan of 911 wheels on a 928, but that's just my personal taste Grab something like this and study away https://www.1010tires.com/Tools/Wheel-Offset-Calculator# Standard offsets for a 928 can be found here http://www.alloywheelsdirect.net/porsche_alloy_wheels/928_928s_alloys Did you ever resolve your fuel tank issue? Link to comment Share on other sites More sharing options...
CHS Posted 3July, 2019 Author Report Share Posted 3July, 2019 29 minutes ago, ANF said: Will they fit - most likely yes, although the offset is wrong for a 928. The fronts will push out 10mm from standard, this could have the affect of tramlining.... or it may not be noticeable? The topic of putting different offsets on a 928 is a touchy one, lots of arguments of what will and wont work.... The rears will push outwards 35mm, will this fit inside the guards, not sure? Also depends on what size tyres you run? Not a fan of 911 wheels on a 928, but that's just my personal taste Grab something like this and study away https://www.1010tires.com/Tools/Wheel-Offset-Calculator# Standard offsets for a 928 can be found here http://www.alloywheelsdirect.net/porsche_alloy_wheels/928_928s_alloys Did you ever resolve your fuel tank issue? Thank you for the info, fuel tank has been replaced by a new one, managed to source fron Germany. Link to comment Share on other sites More sharing options...
