donR Posted 13January Report Share Posted 13January Selling my girodisc set still in reasonable condition. Will fit 718 S or GTS 2.5. Also fits some 981 models, not sure of base. On second disc set measuring 350 x 32.5mm front thickness and approx 325 x 18.7mm rear thickness so still a bit of life left in them with the minimum thickness stated as 32mm front and 18mm rear. Includes caliper spacers to fit larger front and rear disc. RRP over $5200 for the set. New disc replacement is around $1200 to $1500 per set/pair. https://shop.revzone.com.au/girodisc-porsche-981-718-rear-rotors-incl.-spacers https://shop.revzone.com.au/girodisc-front-350mm-2-piece-rotor-upgrade-for-por Selling $1700 + Shipping. Can also supply track pad set, fronts slightly worn but rears due for replacement soon. I also have girodisc caliper stud kit if you need it. Quote Link to comment Share on other sites More sharing options...
