Guest hepkat63 Posted 15March, 2014 Report Posted 15March, 2014 Decided to give the five brake light mod a go today... an hour later all working perfectly. This is a very easy modification and I highly recommend it. How I achieved it: 1. took out rear reflector panel 2. obtained two light sockets from and old tail light I had - these are the two filament ones (you can use single filament, but I wanted lights and brake lights) 3. removed the right hand tail light and disconnected it. 4. using a test light, i put on the lights and then checked which prong was positive. it was the white/blue one 5. Then, i put on the brake pedal (using a brick to hold it) and again, using the test light noted which one was positive - it was the blue one. 6. Armed with this information, i stripped back the wires (note, I did not CUT them, just stripped back some insulation. I then put solder on the wires where they were stripped back. 7. I then cut two pieces of wire - one red, one black (as the wires from the 'donor' filaments had red/black and brown wires) about two feet long. 8. I soldered the red and black wires to the wires I had just stripped (red for lights, black for brakes) 9. Taped all the wires up/insulated them, then fed the wires through the hole towards the middle light panel. 10. I then need to find a common earth. I again put the lights on and using the positive wire - found the earth from the reverse lights using the test light - which was the thick brown wire. 11. I stripped back the brown wire insulation and again, soldered it. 12. I then ran a wire from the brown soldered common earth to the brown wires (so two of them) to each filament. 13. Measuring the red and black wires I had poking through, I stripped back the insulation where they 'passed' the first filament and soldered the red and black wires. 14. At the end of the red and black wires - I then soldered the other ends to the 2nd filament. 15. I then tested it all - everything worked first time. 16. I then taped up all the wires and tucked them all in nice and neat. Job done. So now i have four tail lights and five brake lights.
Caver Posted 16March, 2014 Report Posted 16March, 2014 That's great! Looks so much better! I did a slightly similar modification on the Boxster with the rear foglight. I ran a wire from the right hand foglight across to the left hand foglight, so they both come on now. All the light fittings were already there including a light globe. Somewhere in the wiring, the left and / or right lights are disabled, depending on which country the car is going to. Despite having a wiring diagram and extensive searching, I could not find the connection, so it was easier just to jump the active light to the disabled light.
