DRAPS Posted 23December, 2010 Report Share Posted 23December, 2010 I have a 2009 Boxster S, which has bad brake squel even after the dealer has replaced the pads................any suggestions ? Link to comment Share on other sites More sharing options...
frank964 Posted 23December, 2010 Report Share Posted 23December, 2010 Hi Draps Brake Squeal... You may have high temperature brake pads installed. High temperature brake pads will squeal just as the car is coming to a halt. Mine squeal regularly (so do my brakes, hahaha). There is a product available that is applied to the back of the brake pads, it is designed to eliminate the squealing, this may be your next step if the noise is bothering you. Link to comment Share on other sites More sharing options...
DRAPS Posted 24December, 2010 Author Report Share Posted 24December, 2010 I have a 2009 Boxster S, which has bad brake squel even after the dealer has replaced the pads................any suggestions ? Link to comment Share on other sites More sharing options...
DRAPS Posted 24December, 2010 Author Report Share Posted 24December, 2010 Thanks for the info.........I will check what pads have been fitted and go from there Link to comment Share on other sites More sharing options...
pommygeezz Posted 26December, 2010 Report Share Posted 26December, 2010 copper grease applied to the metal backing of the pad is supposed to cure the squeal, Trev Link to comment Share on other sites More sharing options...
PCM911T Posted 31December, 2010 Report Share Posted 31December, 2010 Some ideas: 1. car not used enough - rusty discs? 2.Pads are too hard. 3.You may have to bed the new pads in by gentle repeated applications to heat the pads up. A track day would sort them out. 4.If they are squeeling both before and after the new pads, have a look for a build up of crud on the outer circumference of the discs, look for a dirt ridge - rotate discs by hand against the side of a screw driver blade or sandpaper.5.Hm 2009 boxster, unless you have been hammering it, you probably haven't done enough K's for new pads??Talk to the dealer, perhaps they should have lightly skimmed your discs before fitting the new pads! Let us know how you go. Cheers Paul M Link to comment Share on other sites More sharing options...
Glenn Posted 1January, 2011 Report Share Posted 1January, 2011 I have a 2009 Boxster S, which has bad brake squel even after the dealer has replaced the pads................any suggestions ? If there was anything untoward with the rotors this should have been identified by the dealer. Try some hard braking a few times in succession and see how that goes. It's worked for me in the past with solving exactly the same problem. Regards, Glenn. Link to comment Share on other sites More sharing options...
