Hellblau82 Posted 17May, 2015 Report Share Posted 17May, 2015 Hey everyone, Here is a comprehensive list of a bulk of the items I need to get my dads car back on the road. dont forget to check out my blog or donate at: https://hellblau82.wordpress.com https://www.mycause.com.au/page/103241/mydadscar any part donations would be greatly apprciated! PM me for further details Part Part no. Notes Fuel System Sender 901 741 801 00 sealing ring 477 919 133 hose 911 201 515 00 connects filler neck hose clamp x2 999 512 348 02 for above hose ^ hose 12x18.5 90mm 999 181 168 50 connects fuel pump hose clamp x2 999 512 554 00 for above hose ^ sealing strap 901 504 932 20 for sealing fuel tank overflow socket 911 201 593 00 overflow hose 901 201 931 00 Suspension front camber bushing for bilsteins elephant raching bushes x2 Steering needle roller bearing 911 347 029 00 bearing that sits inside steering shaft bearing rubber mounting 901 347 223 03 sealing bellows 901 347 393 01 slip ring 911 347 099 05 sits behind steerring wheel switch housing (top) 911 613 099 00 shroud for steering wheel switch housing (bottom) 911 613 312 00 shroud for steering wheel direction indicator switch SIEHE 9/03/10 wiper switch SIEHE 9/03/10 pan head screw 900 014 069 02 screws for steering outer tube (911 347 072 04) Brakes brake caliper repair kit all wheels brake fluid resavoir 911 355 013 13 cable terminal 477 971 939 for resavoir lid 911 355 905 02 for resavoir gasket 901 355 908 00 for resavoir strainer 211 611 381 8 for resavoir hose 4x 1.5 1500mm 020 361 2 for resavoir retaining strap 911 355 038 01 supports resavoir hex head bolt M6x16 x1 900 075 057 02 for support washer 011 524 7 for support brake booster bearing bracket 911 355 382 00 part of brake booster stopper x2 999 703 056 40 stoppers in bracket purchase used vac booster or- hex nut x10 m8 900 076 025 02 spring washer (b8) x 8 012 241 8 Vaccum booster 930 355 027 00 check valve 191 611 933 F attached to vac boost rubber seal for check valve 911 355 921 00 hose clamp x 6 900 2272 003 02 moulded hose 911 355 609 00 attached to check valve brake master cylinder 911 355 011 12 hose 7.5x12.5 65mm 999 181 021 50 attaches to resavoir hose 7.5x12.5 120mm 999 181 021 50 attaches to resavoir intake socket 911 355 322 00 intake socket 911 355 323 00 brake light switch x2 113 945 515 G screws in cylinder sealing ring (o ring for cylinder) 251 611 243 hex nut x10 m8 900 076 025 02 hose 11.8 x4 790mm 999 181 022 51 tunnel boot floor plate dual clip 999 511 112 40 holds brake lines in smugglers box m6 lock nut 999 084 018 02 spring washer A6 012 226 5 hex head bolt M6x22 900 075 016 02 Pedals pedal rubber pad 905 423 511 00 for brake and clutch accelerator pedal 911 423 11 02 whole pedal Body and Frame smugglers box gasket 901 504 491 32 seal for lid of smug box sealing strip bumper maybe 911 505 187 01 mine may still be ok some signs of minor damage maybe save hood 911 511 010 01 may have a lid offered from a user online sealing frame for hood 911 511 127 00 pan head screw m8x20 x4 900 067 057 02 hinge to hood lock ring B8 x10 900 027 015 02 hinge to hood washer 8.4 x10 900 025 007 02 hinge to hood washer 8.4 x10 900 151 008 02 hinge to hood hex head bolt x6 900 075 085 02 hinge to chasis bolt 999 166 043 02 for strut spacer 911 511 332 00 for strut lock 012 645 2 for strut rubber stop x 2 999 7034 036 50 gas pressure spring x 2 911 511 331 01 cover cross panel 911 555 085 00 may have one swan parts windscreen tinted windscreen seal 911 541 225 00 adhesive plate 477 845 043 trim interior windscreen lining interior right 911 555 507 00 30B dark blue windscreen lining interior left 911 555 508 00 30B dark blue Door Pillar lining left 911 555 505 01 Door Pillar lining right 911 555 506 01 Headliner 911 555 055 05 3AD rubber profile x8 644 555 515 00 these fit on ends of headliner support struts doors door trim panel leatherette left 930 555 031 73 3AU color dark blue (this door is in good condition) door trim panel leatherette right 911 555 032 30 3AU color dark blue (driver side door trim ruined) cover strip leatherette 911 555 084 79 30B dark blue sits on top of trim panel RL/R switch x 2 911 613 621 03 auto window switches grab handle 911 555 098 01 grab handle black right Dashboard dashboard trim leather 911 552 056 72 black 1AJ fixing clip x7 999 591 310 40 bush x7 999 591 311 40 latch x2 999 591 344 02 washer A 6.4 x7 011 524 7 lock nut m6 x7 999 090 003 02 heating cover nozzle left 911 552 409 00 cover for heat vents on dash heating cover nozzle right 912 552 410 00 cover dashboard trim black 911 552 550 00 700 black centre nozzle A/c duct 911 571 067 02 cover set 911 552 942 01 front of dash trim covers cover center black 7ae 911 552 944 01 center of dash console trim cover hazard warning light 911 552 471 01 side vent right 911 552 072 00 rosette lid release cable 911 552 217 00 knee protection strip left 901 552 035 70 black 1AJ leather knee protection strip right 901 552 036 70 black 1AJ leather ashtray handle leather 901 552 050 70 black 1AJ leather ashtray 901 552 061 25 fireproof plate 901 552 607 00 hex nut M5 x4 011 005 14 washer 5.3 x4 011 665 3 hex nut M5 x2 011 005 14 washer 5.3 x2 011 665 3 cap nut m4 x2 900 070 001 02 spring washer B4 x2 012 224 3 Decroative fittings sun viser left with mirror 911 731 031 18 black CA9 sun viser right without mirror 911 731 032 04 black CA9 support x2 911 731 331 00 oval head sheet metal screw 900 143 111 07 B 3.9x13 bearing x2 964 731 319 00 tapping screw x4 900 145 075 07 rear view mirrow 477 857 511 A 01C black center console cap 911 552 231 00 stone guard film set rear wheels 930 559 921 00 seatbelts ?? ventalation heating system fresh air inlet box 911 571 032 00 comes with seal, blower, bolts,washer lock nuts oval head screw m5x40 x2 014 153 1 water drain hose 911 571 224 00 hose clamp 999 512 145 02 sealing ring 901 571 922 00 grille frame 911 559 401 00 tapping screw B3.5x13 x4 014 086 12 grille 911 559 410 00 spacer x2 901 559 491 20 control switch 911 613 112 07 wiring harness for control switch 911 612 172 01 bulb 12v, 2w 900 631 132 90 bulb socket 999 632 006 00 sealing ring 914 571 903 10 hex head bolt M6x20 010 217 9 washer 6.4 011 524 7 rubber sleeve bowden control 914 571 151 10 grommet bowden cntrol 911 613 153 00 knob red 901 571 917 00 knob black 901 571 918 00 knob red 911 613 995 00 control box 911 571 049 07 connectin flange x2 911 571 051 00 clamping spring x4 999 512 162 02 speednut x4 999 591 574 02 tapping screwBZ 4.8x19 900 143 039 02 control box 911 571 050 07 distributing piece 911 571 040 00 air hose 911 571 239 00 air hose 473 261 233 A hose clamp 999 512 349 02 air duct 911 571 086 01 sealing ring 911 571 189 00 hose piece 901 571 345 32 heating nozzle 901 572 045 31 retainer 901 571 921 00 air hose 911 571 228 00 hose clamp 999 512 551 00 air hose 911 571 228 00 air hose 911 572 223 00 air hose 911 571 228 00 air distibuter right 911 571 348 01 air distibuter left 911 571 347 01 pan head screw m5x15 x4 044 734 1 lock ring x4 012 005 3 washer 5.3 x4 900 025 003 02 bowden control x2 911 572 114 00 terminal control box 911 571 919 00 grommet 911 612 863 00 sealing ring 901 572 913 01 air hose 914 572 123 10 Front blower Electrical wiring harness luggage compartment harness interior lights harness door mirrors windscreen wiring harness harness rear window wiper wiring harness power windows wiring harness headlight fuel pump warning light mounting plate reley sender fanfare windscreen wiper system windscreen washer system headlight washer system ingterior light system clock instrament pulse sender to tacho auto heating system Link to comment Share on other sites More sharing options...
Stew F Posted 20May, 2015 Report Share Posted 20May, 2015 Did you check the front suspension and steering? I have two SC tie rods and boots in good condition. Recently taken off my car. Was going to EBay them, but let me know if you need them. Link to comment Share on other sites More sharing options...
Hellblau82 Posted 20May, 2015 Author Report Share Posted 20May, 2015 Haven't actually inspected suspension wise I know my shocks seem ok Link to comment Share on other sites More sharing options...
