Jou930 Posted 3October, 2011 Report Share Posted 3October, 2011 Who supplies silicon engine hoses for the 930? I want to replace mine with new hoses but not sure of the measurements and quality suppliers. Link to comment Share on other sites More sharing options...
jnr356 Posted 4October, 2011 Report Share Posted 4October, 2011 3.3's didn't have silicon hoses all pipes are metal with rubber "joiners",except the one into the sensor plate housing which is thick moulded rubber and is usually trouble free. the only one that usually needs replacing is the "cold side" of the turbo,which goes brittle due to heat transfer. have you tried genuine(eg.porsche dealer)? Link to comment Share on other sites More sharing options...
Jou930 Posted 5October, 2011 Author Report Share Posted 5October, 2011 3.3's didn't have silicon hoses all pipes are metal with rubber "joiners",except the one into the sensor plate housing which is thick moulded rubber and is usually trouble free. the only one that usually needs replacing is the "cold side" of the turbo,which goes brittle due to heat transfer. have you tried genuine(eg.porsche dealer)? Thank you Jnr. Link to comment Share on other sites More sharing options...
Jou930 Posted 5October, 2011 Author Report Share Posted 5October, 2011 3.3's didn't have silicon hoses all pipes are metal with rubber "joiners",except the one into the sensor plate housing which is thick moulded rubber and is usually trouble free. the only one that usually needs replacing is the "cold side" of the turbo,which goes brittle due to heat transfer. have you tried genuine(eg.porsche dealer)? I wanted to change the hoses only for cosmetic reasons, using red hoses. I am also thinking of a carbon fibre engine shroud. Link to comment Share on other sites More sharing options...
jnr356 Posted 5October, 2011 Report Share Posted 5October, 2011 if i remember,i'll try and grab a measurement tomorrow do you mean fan shroud?,lot of work on a turbo to change that. if you do you may want to order a set of inlet manifold insulating blocks nearly every set i have removed over the last few years have been cracked, must be getting to the end of their life expectancy Link to comment Share on other sites More sharing options...
jnr356 Posted 6October, 2011 Report Share Posted 6October, 2011 95mm Link to comment Share on other sites More sharing options...
