944 Bits
TINGY
Just wondering if anyone has replaced these items. The first item holds all the cables up against the firewall of the car and is also releasable so it can be re-used and pushes on to the stud you can see in the extreme left of the second pic.
The second item is also a cable clamp and holds the sensor cables up of the engine. Like i said if anyone knows if they are available please let me know or if you have found something similar that is close to being the same as these. I have found some stuff at Wurth's that are similar to the second clamp but not much that is close to the first cable tie.
