RennRob Posted 26January, 2017 Report Share Posted 26January, 2017 Getting the car prepped for some track work, I have installed a fire extinguisher and mount. There are several types of mounts out there, and I chose this one because:1) It attaches to existing mount holes under the seat- no holes to drill, easy to reverse.2) Doesn't require you to remove the seat/ rails.3) Bracket moves with the seat. ie not statically mounted on the rails.http://www.rennline.com/Rennline-Fire-Extinguisher-Mount-Porsche/productinfo/FE01/ Was fairly easy to install. The instructions say to remove the seat, but i found that this is unnecessary if you have reasonably dexterous fingers. Here are some phots Link to comment Share on other sites More sharing options...
Airhead Posted 27January, 2017 Report Share Posted 27January, 2017 Hope you never need it. Link to comment Share on other sites More sharing options...
