NaFe Posted 3August, 2017 Report Posted 3August, 2017 Before I start buying the necessary engine teardown tools I thought I would see if anyone has an engine stand mount (P201) suitable for SC engine.Preferably Melbourne based, but happy to pay postage.Otherwise I'll probably hit up PelicanParts.Thanks, Nath
Mike D'Silva Posted 3August, 2017 Report Posted 3August, 2017 best tool everHowever before I bought the Pelican one, I bought one of these https://www.thesamba.com/vw/classifieds/detail.php?id=956239It really is good quality, but having a flat flange, doesn't allow for the thickness of an oil cooler that your motor will have. You can bolt it to the other side of the case, but from memory, my 2.7 had an oil line that got in the way?I guess you can use a couple of thin shims or spacers or washers, to space it out a bit... The pelican one is pretty schmick though, but 3 times the dollars. I'm willing to part with my "samba" stand.
NaFe Posted 3August, 2017 Author Report Posted 3August, 2017 Thanks Mike,I know what you mean about the cost. Previously, I used the standard fitment with a spare bell housing so I could bench test the engine too. But I also have the rear of the engine supported too.I'll see if anyone has one they are willing to part with, but will keep you in mind...Nath
