tungatina64 Posted 13August, 2012 Report Share Posted 13August, 2012 I have had some modifications done to the rear interior of my car after having the half cage put in. Subsequently some of the carpet was removed exposing some of the overlaps which were glues together. As a result some of the remaining black carpet has that light brown glue/ adhesive stuck/ dried on it. Does anyone have any hints or clever ideas to remove it without taking the Colour out of the carpet? Link to comment Share on other sites More sharing options...
T-Man Posted 13August, 2012 Report Share Posted 13August, 2012 This is a tough one. I would normally recommend 3M-100 Adhesive cleaner though I'm uncertain as to the effect it would have on the dye in the carpet. Heating the glue with a hair dryer or heat gun can help soften it but be careful not to melt the carpet. If you want to disguise the light brown glue you may be able to colour it with a permanent marker!!!! If you want to go the 3M route but find it difficult to source a small quantity to test/try them PM me. Should be able to help. Link to comment Share on other sites More sharing options...
Super FX Posted 13August, 2012 Report Share Posted 13August, 2012 Try some contact cleaner on a rag - first try it on an inconspicuous bit of the carpet but i think it should be ok. If its good then you could probably soak the whole area with it if you need to - but i think a bit on a rag should do.. I´ve soaked shirts, jumpers, jackets, carpets etc with it to clean Synthetic oil and hydraulic fluid out and also found it cleans spray contact adhesive very well. Make sure you get the solvent type and not the oil type for contact and switch gear (lube for mechanical switch gear. eg points). Something like this http://www.lubricantsupplies.co.uk/manufacturer/ambersil-products/ambertron-contact-cleaner-x-400ml-box-of-12.html Link to comment Share on other sites More sharing options...
Broadsword Posted 14August, 2012 Report Share Posted 14August, 2012 MM, You could give Eucalyptus Oil a try (again in a hidden area first). If it doesn't work it will clear the sinuses at least! It is great for removing the left over glue on other surfaces. SV Link to comment Share on other sites More sharing options...
randall Posted 14August, 2012 Report Share Posted 14August, 2012 Sliverknit? Shave it off with a razor. Link to comment Share on other sites More sharing options...
tungatina64 Posted 16August, 2012 Author Report Share Posted 16August, 2012 Thanks for all the suggestions. Just need to find some free time on a weekend to give it a go! Link to comment Share on other sites More sharing options...
