Peter M Posted 3February, 2018 Report Share Posted 3February, 2018 Shed clean out and change of plans as I've foolishly convinced myself to go to 98mm bores and have since bought a set of eye wateringly expensive Mahle pistons to do so. So I have one set of 6 new standard 95mm p&c's in the higher Euro compression ratio that fit will any model 3.2 that are surplus to my requirements. Rings are fitted and each piston is inserted in the cylinder by Mahle at the factory All but one is still in a sealed box. The one unsealed has been opened for photo purposes only. $3950 ono. PM me if interested. Link to comment Share on other sites More sharing options...
Peter M Posted 6February, 2018 Author Report Share Posted 6February, 2018 Pelican Parts have these for sale $3904 plus $169 for shipping or $4073 USD. https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_ENGPIS_pg3.htm#item3 By my calculation, landed here with our sub 80c exchange rate, GST and the duty fee would mean about $5,900 AUD......... Link to comment Share on other sites More sharing options...
Andrew bau Posted 7February, 2018 Report Share Posted 7February, 2018 On 03/02/2018 at 10:41 PM, Peter M said: Shed clean out and change of plans as I've foolishly convinced myself to go to 98mm bores and have since bought a set of eye wateringly expensive Mahle pistons to do so. So I have one set of 6 new standard 95mm p&c's in the higher Euro compression ratio that fit will any model 3.2 that are surplus to my requirements. Rings are fitted and each piston is inserted in the cylinder by Mahle at the factory All but one is still in a sealed box. The one unsealed has been opened for photo purposes only. $3950 ono. PM me if interested. Link to comment Share on other sites More sharing options...
Andrew bau Posted 7February, 2018 Report Share Posted 7February, 2018 9 hours ago, Andrew bau said: Please contact me @ bmbau@hotmail.com thanks Link to comment Share on other sites More sharing options...
Peter M Posted 9February, 2018 Author Report Share Posted 9February, 2018 On 6 February 2018 at 7:44 PM, Peter M said: Pelican Parts have these for sale $3904 plus $169 for shipping or $4073 USD. https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_ENGPIS_pg3.htm#item3 By my calculation, landed here with our sub 80c exchange rate, GST and the duty fee would mean about $5,900 AUD......... Actually the Pelican Parts referenced are the cheaper Graf brand, not the renown Mahle Brand I have for sale. Link to comment Share on other sites More sharing options...
Peter M Posted 15February, 2018 Author Report Share Posted 15February, 2018 Bit more detail: The Mahle part number for each assembly is 503 55 92. If you look up the Mahle Product Catalog you will see that this is the recommended replacement assembly for the 231hp version of the 3.2. In this example for a 930.26 engine type: https://catalog.mahle-aftermarket.com/gb/engine.xhtml?eid=1745&r=0.3293389787578964 If your 3.2 is an Australian delivered MY84 or 85, they are a direct bolt in replacement. If your 3.2 is an Australian delivered post MY 85 car, they are still bolt in but will raise the compression from 9.3:1 to the same as the earlier cars (10.3:1). With the appropriate ECU chip, this will raise the hp from 207/217 to 231hp like the MY84&85 cars. If your 3.2 is a UK car, they where all 231hp across the years and therefore a direct swap. Link to comment Share on other sites More sharing options...
P-Kay Posted 15February, 2018 Report Share Posted 15February, 2018 This is an absolute bargain! If you're doing a rebuild, then get on these. I paid close to twice that for by 98mm....and that was meant to be at cost! Link to comment Share on other sites More sharing options...
Peter M Posted 8March, 2018 Author Report Share Posted 8March, 2018 Surprised that no one has grabbed these already! Might have to keep them for my next 3.2 rebuild if I don't get a serious offer! I guess clearing out my mail box to allow contact might help too.... Link to comment Share on other sites More sharing options...
Peter M Posted 10March, 2018 Author Report Share Posted 10March, 2018 Sold Link to comment Share on other sites More sharing options...
Andrew bau Posted 29July, 2018 Report Share Posted 29July, 2018 On 2/15/2018 at 10:07 PM, Peter M said: Bit more detail: The Mahle part number for each assembly is 503 55 92. If you look up the Mahle Product Catalog you will see that this is the recommended replacement assembly for the 231hp version of the 3.2. In this example for a 930.26 engine type: https://catalog.mahle-aftermarket.com/gb/engine.xhtml?eid=1745&r=0.3293389787578964 If your 3.2 is an Australian delivered MY84 or 85, they are a direct bolt in replacement. If your 3.2 is an Australian delivered post MY 85 car, they are still bolt in but will raise the compression from 9.3:1 to the same as the earlier cars (10.3:1). With the appropriate ECU chip, this will raise the hp from 207/217 to 231hp like the MY84&85 cars. If your 3.2 is a UK car, they where all 231hp across the years and therefore a direct swap. Hi do you still have pistons and barrels Link to comment Share on other sites More sharing options...
Peter M Posted 29July, 2018 Author Report Share Posted 29July, 2018 Long gone Andrew Link to comment Share on other sites More sharing options...
Andrew bau Posted 5August, 2018 Report Share Posted 5August, 2018 On 7/30/2018 at 7:40 AM, Peter M said: Long gone Andrew Thanks Link to comment Share on other sites More sharing options...
