targa george Posted 9February, 2018 Report Share Posted 9February, 2018 996 / 997.1 IPD plenum that fits the factory 74mm E-Gas throttle body. To confirm whether your Porsche is a Cable or E-gas throttle simply look at your throttle body for either a black electronic module (E-Gas) or a conventional spring / cable throttle control. The IPD "Y" designed plenum is a direct factory replacement of the OE "T" style air distributor. From IPD: "The IPD Plenums are a unique design that increases power and torque by optimizing air flow efficiency. Air flow is managed through a diversion splitter that maximizes air speed into the engine. The charged intake air maintains a higher velocity by replacing the factory plastic “T” intake with a stronger and more efficient cast aluminum “Y” design. This unique “Y” style plenum optimizes flow, improving acceleration and boost response. The new IPD replacement plenum eliminates the turbulent air flow by smoothly splitting and diverting the air flow and directing it towards the cylinders at a much higher air speed. This simple bolt-on plenum upgrade provides dyno proven increases in both power and torque throughout the entire rev range. A direct fit, no modifications required for fitment." http://www.ipdplenums.com/products/plenums/carreras/996-carrera http://www.ipdplenums.com/products/plenums/carreras/9971-carreras Can be easily installed (takes about 30mins) - see their instructions here: http://www.ipdplenums.com/images/stories/Installation_Guides/997.1_Installation_Guide_Final.pdf New, current model costs USD$795 new. (more than AUD$1000 shipped). Selling for AUD $400. Delivered. Australia wide. Alternatively, easy pickup, inner west, Sydney. ph: zero four one seven two six seven eight two four Link to comment Share on other sites More sharing options...
Barks Posted 15February, 2018 Report Share Posted 15February, 2018 Is this the Part number 87174-XX ? Link to comment Share on other sites More sharing options...
targa george Posted 15February, 2018 Author Report Share Posted 15February, 2018 Hi Barks I've been a little tardy in updating this thread, my apologies. Plenum has been sold and dispatched as of yesterday. As for part number, I would have that info for you in a flash if it was still in my posession. Again, apologies. targa george Link to comment Share on other sites More sharing options...
