Merv Posted 26May, 2019 Report Share Posted 26May, 2019 My heat exchangers (Australian RHD car) are OK but the J Tubes have seen better days and it seems sensible to replace them. The ones on Stoddart seem fine https://www.stoddard.com/pcg21190100.html , but very expensive for the complete units (assuming they fit). I was thinking that I could remove the existing J Tubes and have the pipes replaced locally using the existing rear flange to the motor) after cutting the old ones near the exchangers and slipping them off the exchangers. Has anyone done this? Or is there another alternative?. Link to comment Share on other sites More sharing options...
9er Posted 26May, 2019 Report Share Posted 26May, 2019 Hey Merv, have some new J tubes that might be handy for a trial of your idea, happy to donate them, I'll flick you some details of diameters and flange a bit later. Link to comment Share on other sites More sharing options...
Merv Posted 26May, 2019 Author Report Share Posted 26May, 2019 Thanks Chris that would be great! Link to comment Share on other sites More sharing options...
9er Posted 27May, 2019 Report Share Posted 27May, 2019 Flange holes 55 c to c tube dia 38 steps down to 34 Link to comment Share on other sites More sharing options...
Merv Posted 27May, 2019 Author Report Share Posted 27May, 2019 Thanks Chris. Mine are the original 1.5" OD (so 38mm is on the money). However my head to J-Tube flange is a different shape? Oblong as shown in this gasket and some tubes. Not sure if yours will fit? Any suggestions, in case I have this wrong? fallout 2 enclave soldier Link to comment Share on other sites More sharing options...
9er Posted 27May, 2019 Report Share Posted 27May, 2019 The flange is the main issue Merv, but I guess if you were getting some cut and shut work done it would be easy enough to swap out? Let me know as I don't need that set and would be happy to donate them. Link to comment Share on other sites More sharing options...
Merv Posted 27May, 2019 Author Report Share Posted 27May, 2019 Actually Chris it is only the RHS that is a problem on my car as the LHS is really good. On the RHS, someone in the past has cut from the very base of the J Tube where it enters the heat exchanger and welded on another straight section of pipe to the muffler. There are two small holes at the dodgy joining point at the heat exchanger. It really does need a new J tube on that side. If it wasn't cut so close to the entry to the heat exchanger, I could do the job again, properly, using your section of straight pipe. I 'could' also use yours and re-weld the existing flange on to it, but the angles are so critical and that worries me. Worth a try! let me know the costs involved please Chris. Link to comment Share on other sites More sharing options...
Merv Posted 28May, 2019 Author Report Share Posted 28May, 2019 Thanks again Chris. I might have to buy the whole shebang from Pelican (Dansk) as the existing heat exchangers are seam welded and would be a pain to split, even if I could get new tubes fabricated. I only hope the horror stories about Dansk exhaust parts are not true! Link to comment Share on other sites More sharing options...
