Ashbaxter Posted 1June, 2019 Report Posted 1June, 2019 Hi all I’m looking for some info on normal door lock behaviour. After reassembling the car some time ago the door locks did not work correctly, now it’s time to get it sorted. This is what’s happening: From inside with both doors closed both lock buttons can be pushed down With drivers door open lock button can’t be pushed down With passenger door open lock button can be pushed down Key will not lock either door With doors locked the key will unlock both simultaneously from either side. Currently to lock the car I have to close the drivers door, lean across from the passenger side to lock it then push down lock on passenger door and close. How should they operate and any tips how how to get there would be appreciated Cheers Ash
Ashbaxter Posted 1June, 2019 Author Report Posted 1June, 2019 All sorted, took handle off and turned lock barrel in drivers door 180 degrees now central locking locks and unlocks as it should
Dreamr Posted 1June, 2019 Report Posted 1June, 2019 24 minutes ago, Ashbaxter said: All sorted, took handle off and turned lock barrel in drivers door 180 degrees now central locking locks and unlocks as it should It's always the simple things ...
Ashbaxter Posted 24July, 2019 Author Report Posted 24July, 2019 Still a bit hit and miss though as sometimes the central locking does not work at all but next time all good
