Nifitsa911 Posted 19December, 2012 Report Share Posted 19December, 2012 HI All, I am new to the forum and it looks like there is a lot of useful content. I have a 1977 Carrera 3.0 which has headlight washers. I have worked out that they are not working because of the relay but it is proving to be hard to find a replacement. It is a 4 pin with the code on it as 12V 5W 002789-00 Brand Hella. I called Hella have not idea of the numbers on this one. I assume because it may be from EU. Any assistance would be greatly appreciated. See pic below: Cheers Link to comment Share on other sites More sharing options...
Russ Posted 19December, 2012 Report Share Posted 19December, 2012 i think you should just be able to walk into a repco/autobarn/supercheap and buy a suitable bosch/hella/triton relay off the shelf? have you tried that? Link to comment Share on other sites More sharing options...
wasserkuhl Posted 19December, 2012 Report Share Posted 19December, 2012 HI All, I am new to the forum and it looks like there is a lot of useful content. I have a 1977 Carrera 3.0 which has headlight washers. I have worked out that they are not working because of the relay but it is proving to be hard to find a replacement. It is a 4 pin with the code on it as 12V 5W 002789-00 Brand Hella. I called Hella have not idea of the numbers on this one. I assume because it may be from EU. Any assistance would be greatly appreciated. See pic below: Cheers Hi this relay can be bought NOS. Part # 928-618-111-00-OEM It is a special relay as it has a timing mechanism in it. So enables you to hit the switch but it only runs for a prescribed time. It costs $99 (USD) pelican parts have them. I replaced mine with a Bosch one, the pins need to be modified but it works, your local Auto Sparky will beable to do it for you in under 5 minutes and for under $30.00. Just don't hold the switch on as it will empty the reservoir very quickly..................... I can post up the relay # and picture if you like? Link to comment Share on other sites More sharing options...
Russ Posted 19December, 2012 Report Share Posted 19December, 2012 oh no, one of those crazy timer ones. ignore my comments then! Link to comment Share on other sites More sharing options...
