WB997.2GTS Posted 24May, 2021 Report Share Posted 24May, 2021 What OBD scanners are you 993 owners using to access the OBD port! I have tried 3 but with limited success. Help? Quote Link to comment Share on other sites More sharing options...
IXLR8 Posted 25May, 2021 Report Share Posted 25May, 2021 I have a Durametric Pro - Option 1. Also note that the 1995 models of the 993 could have had the old round connector and also the newer OBD-II connector. My 1995 has the newer OBD-II connector but it is OBD-I Certified. So if you are hooking up an OBD-II diagnostic tool, it will not work. Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 29May, 2021 Report Share Posted 29May, 2021 If you're after a Durametric I have the enthusiast version in stock Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 29May, 2021 Author Report Share Posted 29May, 2021 Thanks Dan, I have been given a few tips by IXLR8 and need to try those with my existing scanners. What has come to light is that the CAN protocols are the same as early Chrysler and will try connecting with my Autel scanner and Chrysler adaptor.. I would prefer the Pro version as i have 3 Porsche's and quote often tinker with a few mates cars .If anybody in Sydney has the pro version Durametric and would like to try and connect to my ECU it would be greatly appreciated. Warren Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 29May, 2021 Report Share Posted 29May, 2021 Sounds good, we can also get the pro version for you Quote Link to comment Share on other sites More sharing options...
IXLR8 Posted 29May, 2021 Report Share Posted 29May, 2021 10 hours ago, WB997.2GTS said: What has come to light is that the CAN protocols are the same as early Chrysler and will try connecting with my Autel scanner and Chrysler adaptor. I would prefer the Pro version as i have 3 Porsche's and quote often tinker with a few mates cars. Hi Warren, I am a bit confused now. You have a 1996 993 so any OBD-II reader should work to read common codes (P0300, etc) The 1996 993 reads pins 7 (K Line) and 15 (L Line) which is a ISO 9141-2 yet a CAN reads pins 6 (CAN Hi) and 14 (CAN Low). I have a 1995 993 so it would be different. By the way, I also had the Durametric Enthusiast version and used it for 1 VIN on my 993. I later sold it and got the Durametric Pro since I was looking at buying another used 911. Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 30May, 2021 Author Report Share Posted 30May, 2021 Hi Alex, I investigated the OBD plug as per your suggestion and found that although the car is a '96 model it uses ISO9141-2 protocol pin 7 (K1) Motronic Pin 3 (K) Air-bag, CCU, Alm, ABS & pin 15(L). I connected my Autel scanner as generic and it reported back as ISO9141but could only read RPM & throttle position. Using my Bergvill OBD adaptor & Scantto software it finally connected but with limited readings. I need access to a Durametric Pro to check if all is functioning correctly before I outlay the $ on a scanner. Thanks again,,,Warren Quote Link to comment Share on other sites More sharing options...
IXLR8 Posted 30May, 2021 Report Share Posted 30May, 2021 8 hours ago, WB997.2GTS said: Hi Alex, I need access to a Durametric Pro to check if all is functioning correctly before I outlay the $ on a scanner. Thanks again,,,Warren That is what I did before spending the money on a Durametric. I borrowed a Durametric from a local 911 owner for a day, tried it and liked it. What gets me is the support from the company. P codes are not an issue becuase you can Google them, but then Porsche has all these codes such as C152, C141, 4444, etc and Durametric has no clue what they are. Damn, if they are designing a diagnostic dongle, then they should have a list of what all the manufactures codes are. I also wish you can do more coding. I used to have the Ross-Tech dignostic for the VW group cars. A fraction of the cost of the Durametric and it just about did everything. Quote Link to comment Share on other sites More sharing options...
