Redline6 Posted 3September, 2023 Report Share Posted 3September, 2023 If you accidentally overfill the oil then this works a treat to remove the excess without the need to drain the oil tank with the associated mess. Large syringe from Autobarn for around $6 and some tubing. Need about 400mm to reach the oil from the filler neck. TDW911, 911, Stepo and 4 others 6 1 Quote Link to comment Share on other sites More sharing options...
