Pinarelloman Posted 26May, 2013 Report Share Posted 26May, 2013 If you are after a scan type tool that works on P cars, you need a Durametric. I have one & it is a fantastic tool. You use it with a laptop. One feature that can be handy, is when looking at a used car purchase, it can scan the ecu & tell you how many over revs(ie past the limiter), the engine has had. It also tells you total engine hours & can reset ecu warning lights. http://www.durametric.com/default.aspx Link to comment Share on other sites More sharing options...
