MaxzmusSC Posted 24August, 2013 Report Share Posted 24August, 2013 Hey Guys, I had a go at replacing the front inserts tonight and realised I needed a tool to take off the strut insert cap for the boge strut inserts. The tool would look like the alternator fan tool where it's a hollow centre with two pins on either side. Cap being that large dark grey threaded cap below (second item from right to left). Anyone in the lower north shore have one I can borrow for a few hours? Cheers, William. Link to comment Share on other sites More sharing options...
MaxzmusSC Posted 24August, 2013 Author Report Share Posted 24August, 2013 A better pic of the cap. Link to comment Share on other sites More sharing options...
Russ Posted 24August, 2013 Report Share Posted 24August, 2013 there's a few threads on Rennlist and PP about this, and the general consensus is the tool is near impossible to find (sometimes it's included) but that most people use a "pipe wrench" (which look like multigrips to me in Australian speak) http://forums.pelicanparts.com/porsche-911-technical-forum/416918-boge-struts-bilstein-strut-inserts-insert-nut-removal.html Link to comment Share on other sites More sharing options...
SteamWolf Posted 24August, 2013 Report Share Posted 24August, 2013 Stilsons are the industry standard. Link to comment Share on other sites More sharing options...
MaxzmusSC Posted 25August, 2013 Author Report Share Posted 25August, 2013 Thanks guys......hopefully a little degreaser and wrench will work. Can't wait to try out the new braided lines and koni yellows. Link to comment Share on other sites More sharing options...
SteamWolf Posted 25August, 2013 Report Share Posted 25August, 2013 If you do want something better you can get a "pin wrench" / "pin spanner" from ebay. Theres an adjustable one for angle grinders that will work. Link to comment Share on other sites More sharing options...
tazzieman Posted 25August, 2013 Report Share Posted 25August, 2013 Cheap , always works and you will find many other uses , including plumbing Pad the jaws if scratching the gland nuts causes you to wince. Link to comment Share on other sites More sharing options...
MaxzmusSC Posted 25August, 2013 Author Report Share Posted 25August, 2013 worked a treat on driver side but I've run into abit of seizure on the passenger side......soaking it in unlock fluids for a while and will try again later in the day. Link to comment Share on other sites More sharing options...
