Cam Arnott Posted 20July, 2010 Report Share Posted 20July, 2010 -------------------------------------------------------------------------------- Hi guys After agonising for a while I've decided the time is ripe to sell my much loved '71 911. My plans for Historic racing aren't going to amount to much and as such my plan is to sell and buy a nice 964 C2 manual with good a/c - Its almost always a/c weather up here I've owned the car for 5 years and, as you do, spent a whole lot of money on the car, most recently a brand new 2.3 litre twin plug Group N spec engine.($40K) I've done 4 Classic Adelaide's and some lapsprints each year and thats about it. Its never been raced to the best of my knowledge. Asking $83,500 - happy to answer any and all questions. The car will be in Adelaide shortly. Specs are as follows: · Australian delivered 1971 911T with matching numbers bare engine case. · Genuine RS rear flares · Fibre-glass front & rear bumpers & bonnet · New windscreen & seal · Twin battery cut off switches · Polycarbonate head light lenses · Front & rear tow hooks · Elephant Racing front widemouth Carrera oil cooler · Weltmeister front strut brace · Light weight battery Interior · Twin Velo race seats · Monit Rally computer · RS lightweight carpet and door trims · Walker Chassis 6 point roll cage – CAMS approved · TRS 6 point harnesses · North Hollywood Speedometer 8,000rpm converted tacho · Rennline navigators floorboard · Momo Prototipo steering wheel Suspension · Sway Away adjustable spring plates · 21mm front solid torsion bars · 28mm rear hollow torsion bars · Custom valved Bilstein front inserts · NOS Bilstein front struts · Koni rear shocks · New front wheel bearings · New ball joints · Turbo tie rods · Elephant Racing Polybronze front & rear bushings · New front & rear brake rotors & standard M rear and S front calipers · Ferodo DS 2500 brake pads all round & racing brake fluid Transmission 911/901 · Original transmission re-geared to A,F,M,S,X · Seine systems gate shifter on 915 shifter · Wevo transmission mounts · Billet aluminium intermediate plate · Modena LSD · Billet aluminium sideplate · New rear driveshafts Twin Plug 2.3 Motor Case 7R Case – 911/91 from a ’73 2.4 litre motor Supertec Head Studs Case savers, Shuffle pinning, Resurface + line bore, Oil bypass, Modify for turbo pump, Clean + test squirters All machine work by Competition Engineering in the US Crank 66mm S counter weighted crank Cross drilled Balanced & micropolished Pistons 10.5:1 JE (Mark Poole specs) Cylinders Nickies Cylinders – 85.5mm Rods Pauter short stroke – balanced + matched for weight Heads Valves – 46mm intake and 40mm exhaust Twin Plugged Aasco racing valve springs & titanium retainers Heads CNC ported by Steve Weiner (Rennsport Systems) – approx 38mm Induction Tall PMO Manifolds port matched to heads Weber 40 carbs Oil Pump 996 turbo pump Distributor · JB Racing twin plug Exhaust · Cairns muffler, made in Australia, stainless steel. · SSI’s Cams · DC 44 on 102 lobe centres-John Dougherty Starter Motor · Lightweight co-axial (lightest 911 starter available) Call me on 044 888 2399 or email cameron dot arnott at bigpond dot com Some photos here http://www.my105.com/classified.asp?id=16106 Link to comment Share on other sites More sharing options...
Chris-p Posted 20July, 2010 Report Share Posted 20July, 2010 Hi Cam, Sounds like a truly awesome car and I bet a little gut wrenching to sell it. I hope you have success with a sale. Can I suggest that perhaps also get an advert put up on the PCV web site. I have had terrific success selling items there. Good luck! Cheers Chris Link to comment Share on other sites More sharing options...
