frank964 Posted 25January, 2011 Report Share Posted 25January, 2011 Hi Thrillseekers About a week ago I pressed the trip meter button to reset to 0 Km as I was leaving the Petrol Station, the car was in motion and apparently this is a no-no with older 911's(according to another Pcar forum, car should be stationary). I noticed that the odometer and the trip meter stopped turning over as I was on my way home. I rang the man at 'Ringwood Speedometer' and was quoted $98 for the repair so I removed the Speedo from my trusty steed, dropped it off to the man and it was repaired and ready to pick up the next day (24 Hrs). The shop specialises in VDO instruments. So if anyone has any problems with their dash instruments I can highly recommend this shop Frank Link to comment Share on other sites More sharing options...
pommygeezz Posted 25January, 2011 Report Share Posted 25January, 2011 H Frank, my one was doing the same not recording Klms, I went to the same place, got the same service and about the same price,think I paid $100, so not a one off, need my clock repaired next, second hand not working, so I will be going back Trev Link to comment Share on other sites More sharing options...
webrest Posted 26January, 2011 Report Share Posted 26January, 2011 Would agree with Frank & Trev have used them for more than twenty years. Even if they weren't any good they are primarily the only game in town these days. Not that interested in electronics though wont touch cruise controls at all. Dave Link to comment Share on other sites More sharing options...
D-banger Posted 27January, 2011 Report Share Posted 27January, 2011 My P-Car speedo reads 10% over. Can this be adjusted???? I prefer to know exactly what my speed is (without having to perform a calculation). Doug Link to comment Share on other sites More sharing options...
webrest Posted 27January, 2011 Report Share Posted 27January, 2011 My P-Car speedo reads 10% over. Can this be adjusted???? I prefer to know exactly what my speed is (without having to perform a calculation). Doug No problemos Douglas, Ringwood Speedo did mine several years ago, Think it was about $60. Probably more now Dave Link to comment Share on other sites More sharing options...
gaza Posted 12February, 2011 Report Share Posted 12February, 2011 hey guys , new to the forum, was reading about the odometer probs some peole are having and i had the same prom the other week where mine spotted as well. it was great to read about the speedometer shop in ringwood which repairs for about $100 bucks, so i called up and they said bring in the speedo only, so the question is does anyone know if its easy to remove the speedo or do i need to take it somewhere else , my cars a 1996 993 targa. hope someone can help cheers gaza. Link to comment Share on other sites More sharing options...
frank964 Posted 12February, 2011 Author Report Share Posted 12February, 2011 Hi Gaza The speedometer gauge can be removed fairly easily with some patience. The rubber grommet that surrounds the gauge itself is what holds it in place. The gauge basically slides then press fits into the dashboard. To remove the gauge you need to gently prise out the gauge by levering under the outer rim with a flat screw driver, you may even be able to get your finger tips around the rim or try to push the gauge out from behind by putting your hand up under the dash itself. Be careful not to leave an indent in the face of the dashboard from prising with the screwdriver, dont slip with the screw driver or you will score the rim. If you find you need to prise heavily with the screwdriver then pad the shaft of the screwdriver with a soft folded rag. Once the gauge is out of the dash you can simply unplug it. Hope this helps Frank Link to comment Share on other sites More sharing options...
gaza Posted 13February, 2011 Report Share Posted 13February, 2011 Hi Gaza The speedometer gauge can be removed fairly easily with some patience. The rubber grommet that surrounds the gauge itself is what holds it in place. The gauge basically slides then press fits into the dashboard. To remove the gauge you need to gently prise out the gauge by levering under the outer rim with a flat screw driver, you may even be able to get your finger tips around the rim or try to push the gauge out from behind by putting your hand up under the dash itself. Be careful not to leave an indent in the face of the dashboard from prising with the screwdriver, dont slip with the screw driver or you will score the rim. If you find you need to prise heavily with the screwdriver then pad the shaft of the screwdriver with a soft folded rag. Once the gauge is out of the dash you can simply unplug it. Hope this helps Frank Thanks heaps Frank, will give it a go next weekend, let you know how i get on regards gaza Link to comment Share on other sites More sharing options...
Stepo Posted 12October, 2011 Report Share Posted 12October, 2011 Another rap for the Speedometer Shop in Ringwood, VIC. VDO clock stops working overnight in winter due to the cold, worked fine during the day. Replaced capacitors, general clean-up and picked up two days later, $82.50. Very professional job given they have to undo the rolled seal edge and reseal. Thanks for the original tip Frank Link to comment Share on other sites More sharing options...
