smule Posted 29October, 2014 Report Share Posted 29October, 2014 Have just had my door trims off and reconnected my window switches, previously operation of window would rely on accessories being engaged on the ignition Now they seem to operate regardless of accessories position as long as car is unlocked, once car is locked windows become inoperable too. I dont necessary mind this new "feature" but is there a possible drain to the battery as a result of this and should i attempt to rectify ? If so is it a case of one wire in the wrong spot on the switch ? Link to comment Share on other sites More sharing options...
tazzieman Posted 29October, 2014 Report Share Posted 29October, 2014 Has a wire popped off or plug not tight enough? Can you peer down through the window slot with a torch (at night is best)? Otherwise I'd pull the door card again. It's not that tricky. Link to comment Share on other sites More sharing options...
