Stew F Posted 15December, 2014 Report Share Posted 15December, 2014 My strut brace arrived today. Just need to grab some new fasteners tomorrow, 5mm longer, then I can fit it. Whats the best way to get the body sealer off? Soften with a heat gun, or will it just chip off easy enough? Then I need to fit the turbo tie rod kit I got last week. I can see lots of benchmarking and evaluation test drives coming up. Link to comment Share on other sites More sharing options...
tazzieman Posted 15December, 2014 Report Share Posted 15December, 2014 It should just chip off using a piece of plastic or wood Link to comment Share on other sites More sharing options...
Stew F Posted 15December, 2014 Author Report Share Posted 15December, 2014 I had a bit of a poke at it. It seems pretty hard. Maybe an old wood chisel might do the job. A job for tomorrow night. Link to comment Share on other sites More sharing options...
tazzieman Posted 15December, 2014 Report Share Posted 15December, 2014 It's hard but brittle. Once you get started the rest should fall out of place as it were. Link to comment Share on other sites More sharing options...
Stew F Posted 16December, 2014 Author Report Share Posted 16December, 2014 So is it safe for me to take all 3 screws out at once? Link to comment Share on other sites More sharing options...
webrest Posted 16December, 2014 Report Share Posted 16December, 2014 Better if you don't whilst chipping away. Make sure the car is planted firmly on the ground keeping tension on on the top of the strut to the body. You don't want the strut to alter position. Leave two bolts in tightly and work your way around removing and replacing the bolts as you go. Now remove all three bolts and fix the brace into place ASAP and tighten bolts. Don't overlook the fact that undoing those bolts is how you set camber and caster so you want the top of the strut to stay exactly where it is or your alignment may be upset. NOTE. My brace is located in position by two bolts only yours may be the same so obviously you will only need to chip off where required for placement of your strut brace Link to comment Share on other sites More sharing options...
Stew F Posted 17December, 2014 Author Report Share Posted 17December, 2014 Just fitted the strut brace. Brackets needed a little bit of tweaking to get the bolt holes to line up properly, but otherwise, easy as. Took about 45 minutes all up. The sealer isn't as tough as what it first appears. Chipped it off with an old screwdriver. Test drive tomorrow night. Link to comment Share on other sites More sharing options...
