thesnowdrift Posted 12March, 2011 Report Share Posted 12March, 2011 Hey Guys, I am looking at changing my airbox and the new one does not have allowance for oil breather from the tank, anyone know what the risk might be if I just cap of my oil breather? Cheers Pete Link to comment Share on other sites More sharing options...
PCM911T Posted 14March, 2011 Report Share Posted 14March, 2011 Hi Pete, as you say it's a breather! so don't block it off, that would pressurise your crankcase. I have rain hats on my Webers, so fitted a K&N filter with the number (F014B4). Use the existing tube to join, either short or long, as I have seen both arrangements. Cheers Paul M Link to comment Share on other sites More sharing options...
thesnowdrift Posted 14March, 2011 Author Report Share Posted 14March, 2011 Thanks Paul, Thought that may be the case, i need to actually run it back into the airbox as per original but got no idea what parts I need. It just had some badly kinked piece of hose made to fit on there. Pete Link to comment Share on other sites More sharing options...
thesnowdrift Posted 22March, 2011 Author Report Share Posted 22March, 2011 Hi Pete, as you say it's a breather! so don't block it off, that would pressurise your crankcase. I have rain hats on my Webers, so fitted a K&N filter with the number (F014B4). Use the existing tube to join, either short or long, as I have seen both arrangements. Cheers Paul M Just a quick question Paul, do you know anything about the restrictor in this hose, should it be at the oil tank end or airbox end? Thanks Pete Link to comment Share on other sites More sharing options...
