Carrera86 Posted 7June, 2015 Report Share Posted 7June, 2015 anyone had a play with ride heights, the books say ride height of around +- 12mm torsion bar centre and center cap ..... My car 3.2 Carrera is a lot higher than most reading on the forums ,660mm and 665mm measuring floor to lip of guard Euro spec 635 and 645 Any suggestions ..... Link to comment Share on other sites More sharing options...
Harvs11 Posted 7June, 2015 Report Share Posted 7June, 2015 Changing the ride height can be done if you have some decent tools and a day to spare for a first timer. The front is fairly simple, the rears are a more complex job. A lot of assembly needs taking apart to get at the torsion bars. There's a bit of trial and error to get the height just right. When reassembling it helps to set the adjuster screws mid way, you'll need to get the alignment fixed when you're done. This is a good how to... http://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/55-Lowering_the_911/55-Lowering_the_911.htm Link to comment Share on other sites More sharing options...
