PeterP Posted 6July, 2011 Report Share Posted 6July, 2011 Folks, Can anybody offer tips regarding the removal of a drivers seat? My seat is flat, and I have found at a wreckers, a squab (the bottom bit) to replace. So I have to remove my seat, take the top off, then remove the cover and apply it to the new base. Whilst you may have been fooled for a nano second....this is a first for me,and probably something I would first like to try on a Holden Gemini rather than my beloved Porsche !! However, onward and upward; s if there are any tips out there I would much appreciate. cheers Peter Link to comment Share on other sites More sharing options...
jnr356 Posted 6July, 2011 Report Share Posted 6July, 2011 1st you will need a 1/4 drive socket set with a thin walled 10mmm socket slide the seat fully back,this will expose the 2 bolts at the front of each seat rail,remove them next slide seat fully forward,this exposes the 2 rear seat rail bolts,remove them very carefully manouvere the seat out of the car,paying special attention so the rails do not scratc h your linings or worse paint you can even slide the rails back to a central position so they are not protruding done Link to comment Share on other sites More sharing options...
jnr356 Posted 6July, 2011 Report Share Posted 6July, 2011 separating the backrest from the squab is a more trickier proposition and will probably require a more experienced hand,the hardest part disconnecting and reconnecting the tilt lever cable a tricky operation for the untrained,but if you're confident give it a shot Link to comment Share on other sites More sharing options...
