thesnowdrift Posted 21October, 2011 Report Share Posted 21October, 2011 Hi Guys You most probably have seen most of these but just incase... then enjoy the others at the end... ENJOY Pete Link to comment Share on other sites More sharing options...
jnr356 Posted 21October, 2011 Report Share Posted 21October, 2011 fixed the link pete Link to comment Share on other sites More sharing options...
thesnowdrift Posted 21October, 2011 Author Report Share Posted 21October, 2011 fixed the link pete did i bung it? cheers mate...not focused, spent the last couple of days in Octopus position revamping all the Windscreen Washer system on the targa Cheers Pete Link to comment Share on other sites More sharing options...
jnr356 Posted 21October, 2011 Report Share Posted 21October, 2011 have you cleaned out your reservoir? you wouldn't believe the stinking slime dragged out of washer reservoirs 15-20 year old washer fluid ain't no party once that's done it doesn't clag the rest of your system eg,pick-up,pump gears,valves and jets og. pumps can be overhauled if pulled apart gently Link to comment Share on other sites More sharing options...
thesnowdrift Posted 21October, 2011 Author Report Share Posted 21October, 2011 have you cleaned out your reservoir? you wouldn't believe the stinking slime dragged out of washer reservoirs 15-20 year old washer fluid ain't no party once that's done it doesn't clag the rest of your system eg,pick-up,pump gears,valves and jets og. pumps can be overhauled if pulled apart gently so you wont be shocked when i tell you i replaced all the lines the pump was a disaster rusted and seized internals... all sweet now, had to buy new rubber mounts for pump as old ones split when removing the pump... no idea how long it had been unused, years i think... very delicate piece that pump but worth the effort... Pete Link to comment Share on other sites More sharing options...
