Digital Mouth Posted 18September, 2016 Report Share Posted 18September, 2016 HelloIt's time to put a new clutch into the Box and I'm just wondering if a LUK Flywheel will work OK with a SACHS clutch kit?Cheers!! Link to comment Share on other sites More sharing options...
Senor Ed Posted 29September, 2016 Report Share Posted 29September, 2016 Literally just had this completed yesterday. Yes they are the perfect match. I also had the rear main seal and IMS seal done; whilst the gearbox was out. Link to comment Share on other sites More sharing options...
Diggin Posted 29September, 2016 Report Share Posted 29September, 2016 Literally just had this completed yesterday. Yes they are the perfect match. I also had the rear main seal and IMS seal done; whilst the gearbox was out. Hey Ed, how much did this set you back? I did some quick searching on those with Mr Google, and I'm now very nervous about having to replace a clutch in my boxster Link to comment Share on other sites More sharing options...
990SD Posted 30September, 2016 Report Share Posted 30September, 2016 Literally just had this completed yesterday. Yes they are the perfect match. I also had the rear main seal and IMS seal done; whilst the gearbox was out. I'd love to know the dollars involved too Ed if you don't mind sharing. Did the mechanics doing the work give you much feedback about the condition of the rear main seal and IMS seal?cheersDan Link to comment Share on other sites More sharing options...
t888 Posted 1October, 2016 Report Share Posted 1October, 2016 Hey Ed, how much did this set you back? I did some quick searching on those with Mr Google, and I'm now very nervous about having to replace a clutch in my boxsterif you've got a 987.2 (like your profile suggests) then there is no need to worry about the IMS bearing as the .2 doesn't have an IMS. Link to comment Share on other sites More sharing options...
990SD Posted 1October, 2016 Report Share Posted 1October, 2016 if you've got a 987.2 (like your profile suggests) then there is no need to worry about the IMS bearing as the .2 doesn't have an IMS. Hi t888. I'm in the .1 basket. Might add 06 to my profile. Link to comment Share on other sites More sharing options...
Diggin Posted 2October, 2016 Report Share Posted 2October, 2016 if you've got a 987.2 (like your profile suggests) then there is no need to worry about the IMS bearing as the .2 doesn't have an IMS. I know. I was referring to the price for the clutch. Thats why I got a 987.2 (although I missed the bit about the high pressure fuel pump failures. Thank God for Porsche warranty ) Link to comment Share on other sites More sharing options...
Senor Ed Posted 5October, 2016 Report Share Posted 5October, 2016 I bought the clutch kit, the flywheel bolts, the rear main seal and Dual mass flywheel for around $1800 inc shipping from NSW to VIC.Everywhere i read, it recommended doing the IMS seal and the rear main seal whilst the gearbox was out.Total Labour from Porsche Centre Melb was around the $2000 mark. They found a part cracked in there and replaced it also. Bear in mind that they will have to drain the oil out of the engine too so grab a couple of 5ltr packs and take with you. Link to comment Share on other sites More sharing options...
990SD Posted 9October, 2016 Report Share Posted 9October, 2016 I bought the clutch kit, the flywheel bolts, the rear main seal and Dual mass flywheel for around $1800 inc shipping from NSW to VIC.Everywhere i read, it recommended doing the IMS seal and the rear main seal whilst the gearbox was out.Total Labour from Porsche Centre Melb was around the $2000 mark. They found a part cracked in there and replaced it also. Bear in mind that they will have to drain the oil out of the engine too so grab a couple of 5ltr packs and take with you.Thanks for the information Ed. The prices all seem quite reasonable. Where did you source the parts from?CheersDaniel Link to comment Share on other sites More sharing options...
Senor Ed Posted 10October, 2016 Report Share Posted 10October, 2016 Got my parts from Bob Whyms - http://www.bwaauto.com.au/Spoke to Ben in parts. Get a genuine RMS from Porsche. They wont guarantee the RMS if it leaks and is non genuine. Link to comment Share on other sites More sharing options...
990SD Posted 10October, 2016 Report Share Posted 10October, 2016 Thanks for the heads up on the RMS! Link to comment Share on other sites More sharing options...
