Stew F Posted 19April, 2017 Report Posted 19April, 2017 Recently I fitted an aftermarket wheel to my 81 SC. When it was all snugged up I found that there was a gap between the end of the hub and the oyster shells on the column. It was about 8mm. The hub is nearly 20mm smaller in diameter than the oyster shells as well. So i designed this little trim ring to fill the gap. I'll just epoxy it onto the hub. It's been 3D printed in black ABS, and then smoothed with acetone (google it). Turned out real nice.And in case you're wondering, that's my old school Penrite esky.
