dan_189 Posted 9June, 2017 Report Share Posted 9June, 2017 Hey all,Anyone have any experience with a vacuum coolant filling tool? Any specific model anyone is using? From what I've seen the Uview Airlift is quite popular so i'm most likely going to buy that one.Reason I ask is I need to replace the coolant cover on the back right (bank 4-6) of my M96 as it has a very slight intermittent weep from the gasket and need to drain the coolant + refill it.The standard bleeding procedure using the vent valve is too long and complicated so i'm happy to invest in the tool. Thoughts? Link to comment Share on other sites More sharing options...
James P Posted 9June, 2017 Report Share Posted 9June, 2017 Never used the vac tool but replaced coolant many times on GT cars after component replacement / crash. All i do is jack up the rear of the car so the fill tank is above the front radiators & fill it up until it stops taking coolant then run engine to warm then give it some big rev's with the vent valve open, let it cool a bit fill again then drive & fill again etc... yes it can be time consuming but its not that hard.. Link to comment Share on other sites More sharing options...
dan_189 Posted 9June, 2017 Author Report Share Posted 9June, 2017 Thanks James, the vacuum tool makes it look so simple! I already have a compressor so buying tools for it has become a hobby! Going to order one soon, ill report back! Link to comment Share on other sites More sharing options...
