Taffy Posted 27April, 2018 Report Share Posted 27April, 2018 Hi All, Need to replace my transmission mount on my 99 911 996 and i have read the instructions... removal of the transmission is not high on my list of fun. Does anyone in Melbourne have one of these tools and want to hire/lend it out i would be appreciative? Thanks, Taffy Quote Link to comment Share on other sites More sharing options...
simon watt Posted 30June, 2018 Report Share Posted 30June, 2018 WHATS that for Taff Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 2July, 2018 Report Share Posted 2July, 2018 On 6/30/2018 at 3:34 PM, simon watt said: WHATS that for Taff This is to press out the transmission mount on a manual gearbox in a 996 with the gearbox in the car. Actually wish PCM had one because they advised they couldnt replace the mount on my car - preventative maintenance for me anyway so it can wait. Quote Link to comment Share on other sites More sharing options...
time Posted 14March, 2020 Report Share Posted 14March, 2020 Hi Taffy, Did you end up finding an extracting tool? Or a solution to extracting your trans mount? I am in the same boat. My C4's mount needs to be replaced and I'm trying to avoid dropping the trans. And avoid the cost of buying the AGA trans tool. Any suggestions greatly appreciated. Thank you. Cheers, Tim Quote Link to comment Share on other sites More sharing options...
Taffy Posted 5April, 2020 Author Report Share Posted 5April, 2020 Hey Tim, removal was using a hacksaw to cut the rubber and then into the mount until I could crack it and push it out. See pelicans guide. In was a pig, made a pusher using plate, tube and high tensile all thread... get the correct tool as it took me all day of getting different packers from around the workshop to get it to sit. I had to support the transmission off it’s mounts in the car to get clearance. All this was on a hoist, no way would I try it would the right tools on the ground. 996.2 Mercedes box looks way easier. Bolt on mount. Doing again, would buy the tool and then look at selling it after. Taffy Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 6April, 2020 Report Share Posted 6April, 2020 If your mount is in ok condition you can use inserts to save it from degrading more. However there might be some NHV introduced. Quote Link to comment Share on other sites More sharing options...
