Peter 996 Posted 11August, 2020 Report Share Posted 11August, 2020 So, I just picked up the 997.1 GT3 from storage to take it for annual service tomorrow, put the foot on the clutch and the bugger came back up about 25% and then stuck. Put the foot behind and popped it up all the way. It also goes in easily all the way, probably just a little easier before it engages. The clutch feels fine and as i drove the car home, not far mind you only a coupe of km's down the road, it started to get a little better. Anyone else had this problem and what was the fix?? Quote Link to comment Share on other sites More sharing options...
James P Posted 11August, 2020 Report Share Posted 11August, 2020 21 minutes ago, Peter 996 said: So, I just picked up the 997.1 GT3 from storage to take it for annual service tomorrow, put the foot on the clutch and the bugger came back up about 25% and then stuck. Put the foot behind and popped it up all the way. It also goes in easily all the way, probably just a little easier before it engages. The clutch feels fine and as i drove the car home, not far mind you only a coupe of km's down the road, it started to get a little better. Anyone else had this problem and what was the fix?? Get the service tech to check the clutch master & slave cylinder for leaks, if all ok get them to bleed the system its easy (I've done it so many times) Raven 1 Quote Link to comment Share on other sites More sharing options...
Peter 996 Posted 11August, 2020 Author Report Share Posted 11August, 2020 Thanks @James, I’ll get them to have a look at those things tomorrow when I take it in. James P 1 Quote Link to comment Share on other sites More sharing options...
