jm997c2 Posted 16November, 2020 Report Share Posted 16November, 2020 Hi guys, So the time has come to replace the old mounts. I am debating replacing with the standard type / OE design or a semi solid engine mount such as Rennline's semi solid engine mount. Was wondering what your thoughts would be and if anyone is running semi solid mounts? How harsh are they and would you recommend? Cheers Jerry. Quote Link to comment Share on other sites More sharing options...
tomo Posted 16November, 2020 Report Share Posted 16November, 2020 18 minutes ago, jm997c2 said: Hi guys, So the time has come to replace the old mounts. I am debating replacing with the standard type / OE design or a semi solid engine mount such as Rennline's semi solid engine mount. Was wondering what your thoughts would be and if anyone is running semi solid mounts? How harsh are they and would you recommend? Cheers Jerry. If you're car is used every day , Standard or close to that firmness , If a track hack the firmer the better but if you enjoy the the weekend twistys Rennline semi solid would be a good fit Quote Link to comment Share on other sites More sharing options...
jm997c2 Posted 17November, 2020 Author Report Share Posted 17November, 2020 22 hours ago, tomo said: If you're car is used every day , Standard or close to that firmness , If a track hack the firmer the better but if you enjoy the the weekend twistys Rennline semi solid would be a good fit Thanks v.much Tomo. Upon further research I think I will go with Wevo's semi solid mounts. Cheers. THanks again. tomo 1 Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 22November, 2020 Report Share Posted 22November, 2020 You can also use genuine 964RS mounts. I couldn't decide between wevo and RSS mounts so I went genuine. Quote Link to comment Share on other sites More sharing options...
Avon Posted 23November, 2020 Report Share Posted 23November, 2020 I went with RSS mounts to replace the worn out originals in the 996.1 and initially felt there was too much NVH but either they have loosened a bit or I got used to it. Doing it over again I'd just get new originals and replace once they get floppy / droop. Quote Link to comment Share on other sites More sharing options...
